Author Topic: catch tank adapters  (Read 1878 times)
jamie16v
Re: catch tank adapters
« Reply #10 on: 10 May 2013, 20:27 »
basically the outlet from your catch can goes to the tip, if your tip is leaking in atmospheric air, then its air that your maf isn`t reading.  :smiley:
Offline mar_k
« Reply #11 on: 11 May 2013, 07:07 »
I understand that, But when people vent the can to atmosphere they bung the unused bit on the tip,
So my question is, would a leak at the catch can still cause an issue?
jamie16v
« Reply #12 on: 11 May 2013, 13:48 »
as long as the tip is sealed you should be o.k.. you might have issues with mot though due to not recycling the  gasses  :tongue:
Offline mar_k
« Reply #13 on: 11 May 2013, 14:47 »
Ok, cheers Jamie,
MOT wont be an issue though. :smug:
