Author Topic: mk4 gti handling question  (Read 5895 times)
Offline davemk4
« on: 20 April 2013, 11:09 »
Im very happy with current set up of koni uprated shockers and 35mm h&r springs. But find chassis flex and roll quite obcious. My plans are to improve this issue without ruining the daily drive.
Thinks of
Upper front strut brace
Lower s3 brace
Rear anti roll bar
Boot brace
Would all this make a good difference?
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline mcgee9t2
Re: mk4 gti handling question
« Reply #1 on: 20 April 2013, 11:21 »
there the first things ide be doing. if after that I still wasn't happy ide be looking at things like middle chasis braces/unibrace etc
Offline golfyste
  • Project track car
« Reply #2 on: 20 April 2013, 16:51 »
Start with a front and rear anti roll bar as they make th biggest difference.
It's debateable whether the braces do enough to make a noticeable difference.
Offline davemk4
« Reply #3 on: 20 April 2013, 18:13 »
Any advise on brands etc??
Offline golfyste
  • Project track car
« Reply #4 on: 20 April 2013, 18:17 »
Whiteline are a good choice and also eibach, h&r and weitec
Offline markgti1.8t
AGU fk coilovers Powerflex top mounts full 3inch decat turbo back viper induction kit fmic vr6 clutch g60 flywheel catch can 007 forge dv Power flex wishbone bushes  Power flex dog mount under brace JOM  ADJUSTABLE Drop Links Walbro 255lph INLINE Fuel Pump wmi now fitted WAITING TO FIT VR6 MAF SAAB RED TOP INJECTORS STILL TO BUY K300 TURBO  CON RODS LSD
Offline golfyste
  • Project track car
« Reply #6 on: 20 April 2013, 19:04 »
You want bigger then that if possible
And you want to start by getting a rear one as it is what makes the most difference!
Then upgrade the front  :smiley:
Offline davemk4
« Reply #7 on: 21 April 2013, 15:47 »
Rears harder to find a thick one. Neuspeed do 28mm @£230 which fine 22/24mm seem more in 170 range. Take it thickest is best ?
Offline Scott D
« Reply #8 on: 21 April 2013, 15:53 »
whiteline is a good RARB and much better fit than eibach
worth doing rear axel bushes with polyurethane if they are shot - made a big difference when changed mine which were fubared after 40k.
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline davemk4
« Reply #9 on: 21 April 2013, 16:03 »
Previous car club rated whitecline too. Id like to poly thecrear bushes but i know they a pig to do lol
