Author Topic: mk4 gti handling question  (Read 5893 times)
Offline golfyste
  • Project track car
Re: mk4 gti handling question
« Reply #10 on: 21 April 2013, 17:22 »
Yeah the thicker the diameter the less roll and more trackcarish it becomes
You wouldn't new 28mm on the rear but you want more than 22 on te front as that is the same as standard.
Offline davemk4
« Reply #11 on: 21 April 2013, 17:48 »
That good to know. Ill get thickest possible as really wanna sort this roll out
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline Sirocco20348
« Reply #12 on: 22 April 2013, 09:48 »
Ok I am being dead serious.
You have already ruined the handling off your car by lowering it.
Nothing you have suggested will rectify the problem.
You either need to install some h2 sport spindles, or return your car to standard suspension height.
Offline golfyste
  • Project track car
« Reply #13 on: 22 April 2013, 09:50 »
Ooooo the noob is dead serious  :whistle:
« Reply #14 on: 22 April 2013, 10:49 »
looking at how low your car is, your handling would be subpar aswell
Offline golfyste
  • Project track car
« Reply #15 on: 22 April 2013, 10:55 »
You mean my sig?? you see Cars do go quite low when you have 5 people in 2 surfboards, a 20kg tent and a weeks worth of camping stuff  :laugh:
Offline GTi_James
« Reply #16 on: 22 April 2013, 11:16 »
handling increased with lowering the center of gravity, add to the vehicle uprated and thicker ARB's means less bend on the ARB resulting in straighter wheels on a corner.
these kits would not be designed and placed on all sports cars if they were useless  :rolleyes:
« Reply #17 on: 22 April 2013, 12:02 »
Its been documented a million times over the net that the mk4 golf is already at its limits at the stock suspension height.  The control arms are already parallel with the ground.  When you lower the car, you bring on unwanted positive camber, so when you go around corners at full speed it feels worse than it did with the stock setup.
It might feel 'stiff' and 'tight' at low speeds when your cruising through McDonald's drive through, but at the track it is useless.
« Last Edit: 22 April 2013, 12:04 by Sirocco20348 »
« Reply #18 on: 22 April 2013, 12:14 »
OMG haha such a noob comment, you have a lot to learn my friend.
These kits are more often designed for looks rather than actually solving the problem of making the car handle better.
Its well known that the Shine suspension kit is the best handling setup for the golf iv.
Standard height at the front, rear is dropped by an inch.
« Last Edit: 22 April 2013, 12:15 by Sirocco20348 »
Offline mcgee9t2
« Reply #19 on: 22 April 2013, 12:50 »
funny how i drive around a round about each day 3rd exit, before i lowered my car anything over 35mph and the car understeered and wasnt able to get around it. after lowering i can take it between 45-50...
