Author Topic: catch can  (Read 5277 times)
Offline golfyste
  • Project track car
Re: catch can
« Reply #10 on: 14 April 2013, 18:40 »
that'll be a no then...
Sorry didn't see your post  :laugh:
I seem to recall somebody cutting one in halve to check and there not being anythin inside
Its all about the saikou michi  :grin:
Offline markgti1.8t
Re: catch can
« Reply #11 on: 14 April 2013, 19:11 »
so how do i get it to work
AGU fk coilovers Powerflex top mounts full 3inch decat turbo back viper induction kit fmic vr6 clutch g60 flywheel catch can 007 forge dv Power flex wishbone bushes  Power flex dog mount under brace JOM  ADJUSTABLE Drop Links Walbro 255lph INLINE Fuel Pump wmi now fitted WAITING TO FIT VR6 MAF SAAB RED TOP INJECTORS STILL TO BUY K300 TURBO  CON RODS LSD
Offline golfyste
  • Project track car
Re: catch can
« Reply #12 on: 14 April 2013, 19:14 »
all you can do really is cut it open and stuff it full of wire mesh and wire wool although you need to be careful of the woll beings sucked into the intake
Offline markgti1.8t
Re: catch can
« Reply #13 on: 14 April 2013, 19:23 »
the bottom of it screws open so do in put the mesh in fist then wool
Offline crazy golf
Re: catch can
« Reply #14 on: 14 April 2013, 19:24 »
whats that disc thing? prety sure i dont have it..
Offline golfyste
  • Project track car
Re: catch can
« Reply #15 on: 14 April 2013, 19:26 »
I haven't done it before so you will have to have a look and figure it out but i would think that you want to put some mesh in first and then some wool and the mash will act as a filter to stop the wool going into the intake. (Depending how course they are)
Offline rio_gti
Re: catch can
« Reply #16 on: 14 April 2013, 20:50 »
Prob doesn't help that
1) there as a massive kink in one of the pipes
2) you left the pcv valve in there
Or am I imagining things  :undecided:
Offline markgti1.8t
Re: catch can
« Reply #17 on: 14 April 2013, 20:53 »
there is in the pic but i have fixed it what do you mean by the pvc valve
« Last Edit: 14 April 2013, 20:55 by markgti1.8t »
Offline rio_gti
Re: catch can
« Reply #18 on: 14 April 2013, 20:58 »
This part should be removed and the pipe goes straight into the elbow
Offline rio_gti
Re: catch can
« Reply #19 on: 14 April 2013, 20:59 »
And then block the vacuum pipe off (top one that goes to the mani)
