Author Topic: Flywheel Lightening  (Read 15128 times)
Offline xionsolaris
Re: Flywheel Lightening
« Reply #20 on: 11 April 2013, 21:27 »
Ah so its only when the clutch bites you give it a bit more revs
Offline spikenipple
« Reply #21 on: 11 April 2013, 21:35 »
Hmm maybe I should turn mine down a bit more.... 2.5kg off isn't as much as most people have taken off it seems. The livelier the better  :evil:
Offline sharki786
  • GOT BOOST??
« Reply #22 on: 11 April 2013, 22:23 »
Wouldnt go too low. Youtube flywheel fail and see how much damage it will cause :shocked:
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline spikenipple
« Reply #23 on: 11 April 2013, 22:51 »
I've machined mine to 7kg for now. Weighed in at 9.5 to start with. Will be a few weeks before I fit it anyway but I don't want to be underwhelmed with the difference when it goes on...
Offline Dave_IOW
« Reply #24 on: 12 April 2013, 00:13 »
Same weight as mine, was a fair difference for me, although I was coming from a dual mass mk4 item.
However many mentioned the lighter pedal feel when swapping out a dual mass, but nobody mentioned any difference for Liveliness, which there certainly was in my case, so I guess it must have made a significant change.
I also noticed that coming off throttle, the engine brake was a lot stronger, less rotational force I guess. This could be classed as a downside.
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline tweed
« Reply #25 on: 12 April 2013, 06:46 »
More engine breaking the better  :evil:
Offline Len
« Reply #26 on: 12 April 2013, 08:51 »
Having now seen pics of my original and spike's turned down one (its in "what have you done to your Golf today") where the metal is taken away from should have no effect on the clutch bearing area.
I would suggest that a flywheel failure is more likely to do with imbalance or a faulty fitted clutch.
www.sas.org.uk
www.the-ace.org.uk
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #27 on: 17 April 2013, 16:36 »
Received my new lightened and balanced flywheel today,  it weighs exactly 7kg. Now to raise some cash for a Sachs  Vr6 clutch kit and  fitting...
Offline Len
« Reply #28 on: 18 April 2013, 12:55 »
Taking mine to be done this weekend
www.sas.org.uk
www.the-ace.org.uk
Offline tshirt2k
  • Been there...Done that...
« Reply #29 on: 22 April 2013, 14:13 »
If anyone is going to turn down their own flywheel, it's best to make sure it's balanced, as per hotgolf or you could knock something out on your bottom end. Possibly.
Mk3 ABF 16VT Megasquirt V3
