Author Topic: CHEAP Clocks Mods - Heads Up  (Read 12470 times)
Offline Ashmond
  • Money, b!tches And Boost
Offline GTi_James
Re: CHEAP Clocks Mods - Heads Up
« Reply #1 on: 04 April 2013, 11:31 »
i'd want the anni needles though as well lol
Offline Nino
« Reply #2 on: 04 April 2013, 11:46 »
Have you done this ash? And isit hard to do?? This really interests me :)
Current - MK6 GTi Edition 35
Offline Ashmond
« Reply #3 on: 04 April 2013, 11:54 »
My clocks are basically the anni bits with my standard Gti guts....I made them fit  :grin:
To be honest, the anniversary needles arent all that, look at the photo below, the centre of the needles are black whereas the Gti ones are red all the way through. I swapped them, then deceided I preferred the gti ones so I changed the temp and petrol needles back but kept the main needles as the anni ones.
Its a piece of piss to do you just need to make sure when you put them back to 0 that the needles are at 0, when you turn the keys on in the car, they will recalibrate and maybe slightly off....i had to take mine apart 3 times to make sure they were spot on.
Its such an easy mod to do. If anybody has or comes across TT/r32 needles then il gladly swap my anni ones as they are the same but the middle circle on the needles is silver instead of boring black.....
« Last Edit: 04 April 2013, 11:58 by Ashmond »
Offline Ashmond
« Reply #4 on: 04 April 2013, 12:02 »
(With the anni rev/speedo needles and the gti fuel/temp needles)
Offline asboGTI
« Reply #5 on: 04 April 2013, 12:22 »
loving these ash great work as always
vw golf mk4 ARZ 1.8T pipercross panel filter, xenon headlights, JOMS coilovers, forge 007p with green spring, audi tt anti roll bar, 3inch ebay trubo back exhaust, COOKIES MONSTER STICKER(adds bhp I swear)
Offline Ashmond
« Reply #6 on: 04 April 2013, 12:50 »
Just for people who wanna give it a whirl and do something different. I am yet to see a mk4 with the carbon fibre backing. I cant do it on mine just clocked as the silver rings on my anni ones are one piece, dont want to risk trying to split and damaging them
Offline Nino
« Reply #7 on: 04 April 2013, 13:01 »
I did something sililar to my ford focus i got lockwood dails and changed the entire backing lighting too took me ages althou i didnt take te needles off as they were prone to breaking and found it extremely hard to get the new dails on. How hard isit to remove the needles?
Offline Ashmond
« Reply #8 on: 04 April 2013, 13:13 »
I was going to change my SMD's to white or red but tbh I just love the VW standard blue clocks....looks crisp at night!
If the needles never been removed just get a flathead screwdriver and something on the end not to scratch the clocks....I used tape but a thin microfibre would be better. Just apply even upward pressure and they pop off. You do need to give it a bit of welly but not too much....hard to explain.
The Anni needles on the back are MUCH shorter then the Gti so I had to fit down the lip on the guts to make the smooth. Sounds complicated but it is actually SO easy. Might start making some up if people are interested (not on your own clocks, on some clocks then sell)
Offline davemk4
« Reply #9 on: 04 April 2013, 17:12 »
Good link depends on epc light postion etc as that thecissue just swapping clocks aint it
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
