Author Topic: CHEAP Clocks Mods - Heads Up  (Read 12461 times)
Offline Nino
Re: CHEAP Clocks Mods - Heads Up
« Reply #10 on: 04 April 2013, 23:47 »
Kook Ash, can I ask u know where to get dials that look like the anni ones? As the passat ones don't have the silver strip :) also how exactly do you're move the clocks from the car?
Current - MK6 GTi Edition 35
Offline Immortal
  • 1.8 Turbo GTI (AUM)
« Reply #11 on: 05 April 2013, 01:07 »
I think ash has the bora sport foils (same as me). They're pretty sweet :cool:
Offline davemk4
« Reply #12 on: 05 April 2013, 06:35 »
I will add creation motorsprt have exclusive bora replica foils too. More expensive than 5 quid mind
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline Granta Gti
« Reply #13 on: 05 April 2013, 07:08 »
They about £30 quid and a couple of quid postage I think. Don't be put off this is easy to do !
Offline davemk4
« Reply #14 on: 05 April 2013, 08:10 »
Im not i bought em  :cool: BUT as my clocks seem odd i font think any foil replacement will work right as even alk the richbrook dial foils wont work on mine :cry:
Offline Ashmond
  • Money, b!tches And Boost
« Reply #15 on: 05 April 2013, 08:34 »
No I have the proper bora sport clocks; foils, needles and thick silver rings built into the casing
I just swapped them over as the SMD's didn't work on the original sports motherboard.
The passat ones are the most similar to r32 foils. Just needles you need. Like I said if anybody gets any r32 or TT needles il swap my anni ones
Offline Perryd84
  • MK4 Golf 1.8T 20V GTI
« Reply #16 on: 06 April 2013, 15:03 »
http://www.ebay.co.uk/itm/VW-MK4-BORA-SPORT-CLOCK-OVERLAY-INSTRUMENT-CLUSTER-FIS-/160764236532?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item256e4b92f4
I got this for my AGU really good quality not just some paper or card insert. Put on some chrome rings as well really sets it off looks well smart  :cool: I prefer the GTI needles to be honest they seem to glow a lot more then the anni ones.
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
Offline davemk4
« Reply #17 on: 06 April 2013, 17:12 »
Ohhhhh they do AUM clocks too!!! Ill be checking this out if the boras ive got are no good cheers for that
Offline davemk4
« Reply #18 on: 06 April 2013, 19:39 »
god dammit for god sake not a single dial kit is the same as mine none of the bora, creation motorsport or lockwood. my issue is both the EPC light on mine is near the 6k not k and i only have 3 centre lights above the display too. if mine not same as early gti and not same as late type what have i got............??????????/
Offline davemk4
« Reply #19 on: 06 April 2013, 19:52 »
Mine
