Author Topic: JOM coilover warranty? update 11/05/13  (Read 4412 times)
Offline Chris#101
« on: 03 April 2013, 18:30 »
How do, Ive got a set of JOM coilovers on my car and they were brand new when i brought them and were fitted lastyear on 26/07/2012. so around 8months old
the last few weeks the drivers front shock seemed to be getting harder and harder and im getting a really bad vibration/steering wheel shake at around 70mph.
Under closer inspection the driverside front shock seems to be leaking  :lipsrsealed:
Where do I stand with warranty?
anyone ever dealt with problems with JOM coilovers?
cheers
« Last Edit: 11 April 2013, 17:54 by Chris#101 »
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline dom
  • Back in a Mk4
Re: JOM coilover warranty?
« Reply #1 on: 03 April 2013, 19:55 »
I tried to get mine replaced under warranty with the exact same problem. I got absolutely nowhere with it, JOM replied to e-mail in broken english and wanted nothing to do with it.
The vibration/steering wheel shake is probably unrelated though...lost wheel weight maybe, checked for bulges in tyres?
Offline Dalo Harkin
« Reply #2 on: 03 April 2013, 20:04 »
Someone else had a shocking experience with JOM on here with some  lights, I wouldn't touch them with a barge pole now
Offline DubAndDubber
« Reply #3 on: 03 April 2013, 23:30 »
I had two faulty fronts. They were really helpful, I had to purchase the replacements though. But as soon as they collected the faulty parts the purchased shocks were refunded in a few days.
They didn't offer me this solution but I asked if it was possible, to which they agreed. Give them an email, see what they say I suppose!
Mk5 Golf Gti 06'
Offline crazy golf
« Reply #4 on: 04 April 2013, 01:35 »
They cant make there front grills fit right, so god knows what there coilovers are like  :huh:
Offline davemk4
« Reply #5 on: 04 April 2013, 07:46 »
Where did you buy them from? It the sellers responsibility to sort this. You will still have 1 year warranty against defects?
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 04 April 2013, 11:10 »
1 year manufacturers warranty, not reseller warranty
Offline dom
  • Back in a Mk4
« Reply #7 on: 04 April 2013, 17:17 »
As Wazzzer says, it's a manufacturers warranty. The company you buy them through just refers you directly to JOM.
Offline davemk4
« Reply #8 on: 04 April 2013, 17:30 »
Yes but as the sales of good act states it you shouldnt be fobbed off to manufactuer it sellers responibility to furfill the manufactuers warranty. I work in retail so weather it different in car world i dunno...
Offline Chris#101
« Reply #9 on: 04 April 2013, 17:32 »
Well i brought them off an eBay shop and they came with 2 year warranty  :smiley:
Il contact the seller and see what they say  :smiley:
Hopefully il get a set of fronts as if ones leaking it won't be long before the other will start
