Author Topic: Coolant/antifreeze change.How to?  (Read 3661 times)
Offline Leebob
  • Jetta Sport TDI cr170,Mk3 Colour Concept 8v
« on: 15 March 2013, 21:17 »
Fancy having a go at doing this myself and I know this topic has been covered a bit before but im still not confident and sure of how to do this.If someone could please post a simple step by step how to up so I could have a crack at doing this myself it would be much appreciated.Thanks Lee
Offline Foreveryoungaus16v
Re: Coolant/antifreeze change.How to?
« Reply #1 on: 15 March 2013, 21:19 »
Look at the Haynes Manuel or Google.
163 BHP (TSR POWER RUN)
Offline Gash
« Reply #2 on: 15 March 2013, 23:51 »
simple step by step guide?
if you just want to draing the coolant not flush it then...
bottom rad hose off (coolant from rad/engine will come out)
hose that goes into the block from heaters box off (youl see it)
wait until no more comes out.
reconnect
60% coolant 40% water mix. so 4 litres coolant, 2 water
pour in via expansion tank, leave the cap off
engine on
while on squeeze the hoses you can get to to push out air bubbles
do this until engines at around 90 and or you see no more bubbles coming from the expansion tank.
should be it.
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #3 on: 16 March 2013, 00:04 »
reconnect
engine on
should be it.
Think I should do mine on my 20vt......Does it have to be G12 or something like that?
Gavv8
« Reply #4 on: 16 March 2013, 10:08 »
G12 is oem spec, i'm not convinced that its any better for an old high mileage 8v than any other branded coolant but for the VR/16V/20V its probably the right choice.
Offline Leebob
« Reply #5 on: 16 March 2013, 15:15 »
Cheers lads.How do i go about flushing the system out if I choose to do this?And where can I get my hands on some g12?
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #6 on: 16 March 2013, 16:12 »
G12 can be bought from TPS or Euro's if I remember correctly mate. As for flushing......I think it is a case of draining all your coolant then putting a hose pipe in your expansion bottle with the bottom hose still off your rad and letting the hose run for 10 mins or so which should clear all the cr@p out.
Offline Leebob
« Reply #7 on: 16 March 2013, 16:34 »
Cheers buddy
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #8 on: 16 March 2013, 23:19 »
Did mine the other day whilst replacing the thermostat got mine from the stealers G12 is now G13 and was £8 for 1.5ltr bottles
2000 Mkiv GTi 1.8T AGU
Offline dixie180
  • Mk3 8v Gti,Mystic Blue the best colour.
« Reply #9 on: 17 March 2013, 17:38 »
Got 5 litres of ready mixed G12 from ECP with a can of WD40 using discount code.Delivered to my door for less than £9 all in. :cool: :cool:
