Author Topic: Just had to remove this...but what is it??  (Read 1106 times)
Offline hardmonkeys
« on: 12 March 2013, 17:13 »
Just had to connect rear washers back up as connection had come off...had to remove this...but what is it?? It looks something should connect to it...but can't find anything...
Any ideas?? Car is a 1.8 20v GTi
Warren
'05 VW Golf Mk V GT TDI Laser Blue
'98 VW Golf Mk IV GTi Black
'97 VW Golf Mk III GTi
'58 VW Golf Mk V GT Sport TDI Steel Grey
'10 Audi A4 B8 SE Multitronic
'00 VW Golf Mk III.V Cabrio
'12 Audi A5 S Line Black Edition
'03 VW Golf V6 4motion
MK3.5 Cabrio 2.0 8v Automatic to 2.0 16v Manual Conversion Project
http://www.golfgtiforum.co.uk/index.php?topic=272728.
www.dorsetautorestore.co.uk
Offline gm8
Offline hardmonkeys
Re: Just had to remove this...but what is it??
« Reply #2 on: 12 March 2013, 17:57 »
Thank you! What effect does it have if you remove it.
Offline jimmyGIT
« Reply #3 on: 13 March 2013, 07:37 »
You tell me bud :grin:!!!,Mine just sits there ticking away in the corner,Emissions anyone?? sorry thats my limit with this. :undecided:
Offline jonrandom
« Reply #4 on: 13 March 2013, 07:52 »
It can throw up a fault code if you dont fit a resister and vent the fuel emissions out through the arch
Offline hardmonkeys
« Reply #5 on: 13 March 2013, 17:08 »
Is that what the pipey thing is in the bottom? Just a breather? Nothing connects to it??
What's the benefit in removing?? Is there point? I started it without it, just to see what happened...it's sounds lumpy as hell...really rough...
It's all back in now lol
Warre
Offline jonrandom
« Reply #6 on: 13 March 2013, 18:09 »
Its mainly removed to remove all the vac hoses to stop leaks.
Copied from somewhere
In a nutshell, the vapor canister was designed to "catch" le fuel vapors when the engine is turned off and just sitting there, so the next time the car starts it sucks them back into the engine and uses them.
it is an "emissions" thing, you don't really need it to run, it's just there to save the environment.
Offline hardmonkeys
« Reply #7 on: 13 March 2013, 18:56 »
Ahhhh ok then! That explains it. Thanks :-)
Warren
Offline rio_gti
« Reply #8 on: 13 March 2013, 20:41 »
prob would have ran lumpy if you didnt block the vacuum
