Author Topic: mk4 1.8 Turbo Gti. Turbo question?  (Read 3143 times)
Offline Sonic B0000M
  • 1.8 T AUM 205BHP
« on: 03 March 2013, 02:02 »
Just got a GTi. Its 2001 51 plate.  Which turbo is it? I heard there is a better one around my year?
Offline xodia
Re: mk4 1.8 Turbo Gti. Turbo question?
« Reply #1 on: 03 March 2013, 09:18 »
More than likely you are running the AUM engine code, which has the k03s, which is the better turbo, and you have variable valve timing, which when mapping releases extra ponies!
If you cant find out your engine code, probably the easiest most noticeable difference is if you look under the bonnet to see if you can see the throttle cable, if you cant see one, you are most likely running electronic throttle, which the AUM and above engines do. If you do see a throttle cable, you are running an AGU engine code, which has the k03 turbo
Hope this helps :)
Offline brewey
« Reply #2 on: 03 March 2013, 09:30 »
ARZ is also drive by wire (no cable) and was in golfs around 2000-2001. These engines have the older K03 turbo but supposedly have stronger internals than AUM/ AUQ.
Take off your engine cover and look at the tag on the block your engine code will be etched into it.
2000 1.8T ARZ - OEM+
Offline golfyste
  • Project track car
« Reply #3 on: 03 March 2013, 16:49 »
At that age (late 2001) it should be a aum as They only made the arz for about 6 months in 2000 but some weren't sold untill 2001
Te aum has the k03s and as said vvt which is good.
The arz and aum/auq have exactly the same internals.
Agu has large port head which I the main bonus of the old engine but on all the engine the rods are the weak points!
Offline kane_turbo
« Reply #4 on: 03 March 2013, 17:57 »
no need to get your hands dirty playing in the engine bay. go to the boot lift the carpet up on the left hand side there will be a sticker. and givesw you all the data you need. :D engine code colour ect ect.
Offline brewey
« Reply #5 on: 03 March 2013, 20:24 »
I thought that the AGU and ARZ had forged cranks which the later engines didn't have?
Offline golfyste
  • Project track car
« Reply #6 on: 03 March 2013, 21:11 »
The agu and bam have a forged crank but it is irrelevant unless your hitting silly numbers like 800bhp!
Never heard of a cast 1.8t crank snapping on any of the high powered cars.
  • 1.8 T AUM 205BHP
« Reply #7 on: 03 March 2013, 21:23 »
How much quicker is the s? And exactly how much quickerbis remap to say 200bhp? What's the 0-60 like. ?
Offline golfyste
  • Project track car
« Reply #8 on: 03 March 2013, 21:42 »
Standard they are pretty much the same (s has a bit more low down torque I think...bits it's minimal)
K03 will map to around 180-190
K03s will map to 200-210 or with mods upto around 235+ depending on mods
Having a map makes a massive differnece! Totally transforms the car and is the best things around in my eyes!
  • 1.8 T AUM 205BHP
« Reply #9 on: 03 March 2013, 22:44 »
My documents say AUM. I take it that I own the K303s   :grin:
