Author Topic: Changing the radiator on an aircon model mk3  (Read 11732 times)
Offline murraymint
« on: 15 February 2013, 18:15 »
I need to change the radiator on my 16v as its pissing out coolent. My question is how easy a job is it? Do I have to disconnect the aircon rad? As I don't fancy paying to get the aircon recharged.
Josh
josh
Offline mad4vws
Re: Changing the radiator on an aircon model mk3
« Reply #1 on: 15 February 2013, 18:27 »
but of a job but full front has to come off .air con rad is screw to other radiator so you don't have to disconnect air-con rad .... :wink: :smiley:
BREAKING VW GOLF'S
Mk2/ MK3'S ALL DAY LONG. PM FOR ANY PARTS!!  ON 07813936583
Offline murraymint
« Reply #2 on: 15 February 2013, 18:51 »
Soo the whole front has to come off but I can leave the air com rad pipes connected yh?
josh
Gavv8
« Reply #3 on: 15 February 2013, 19:01 »
Pretty sure you can do it without taking the front off the car.
Offline N900 MJT
« Reply #4 on: 15 February 2013, 22:42 »
Na the front needs to some off as that's the only way to get the rads out, you will need to get the aircon regassed if you do undo it
Offline hobbiniho
« Reply #5 on: 16 February 2013, 16:14 »
nope whole front has to come off but shouldnt take much longer than 30 minutes to strip apart
Offline Khare
  • The bear that khares
« Reply #6 on: 16 February 2013, 16:30 »
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #7 on: 16 February 2013, 17:38 »
Yep,  A/C condenser has to be removed im afraid therefore depressurised.  It's not difficult but those aluminium A/C pipes are extremely fragile  so be careful un tightening them.
As the system will be apart it's advisable to replace the dryer whilst you're at it before getting it regassed seeing as they're designed to absorb moisture from the lines and it'll now be open to the air .
« Last Edit: 16 February 2013, 17:41 by thai-wronghorse »
Offline murraymint
« Reply #8 on: 16 February 2013, 18:04 »
Fecking aircon!!!!!! Cheers for the info.
josh
Offline tweed
« Reply #9 on: 16 February 2013, 19:23 »
try fitting a 80mm cold air feed from the lower vent then  :laugh:
