Author Topic: Changing the radiator on an aircon model mk3  (Read 11733 times)
Gavv8
Re: Changing the radiator on an aircon model mk3
« Reply #20 on: 16 February 2013, 22:18 »
looking for a 5 door  :whistle:
Fu**ing traitor!!
Offline murraymint
« Reply #21 on: 17 February 2013, 00:16 »
Get a specialist to drain the AC system first, do the radiator then get it regassed.
Specialist??! Naa just undo it and run away!!!!!  :laugh:
Fu**ing traitor!!
Still love the mk3 but 60 mpg is way better then the 25/29mpg I'm getting in the valver
josh
Offline Len
« Reply #22 on: 18 February 2013, 11:13 »
I did my radiator without disconnecting air-con rad or any air-con fixings!
And didnt take all the front of the car off either! :smug:
Pig of a job though!
www.sas.org.uk
www.the-ace.org.uk
Offline Len
« Reply #23 on: 18 February 2013, 11:22 »
Apologies, just checked and I did take bumper and crossmember off!
www.sas.org.uk
www.the-ace.org.uk
Offline Bellend
« Reply #24 on: 18 February 2013, 12:26 »
This. I've removed one before and fitting could be done. Just fiddly.
Where all my moneys went.
Offline Len
« Reply #25 on: 18 February 2013, 12:32 »
Yea thinking back now I did have to cut out a section of a plastic flange to clear a pipe connector.
And I think I pulled the rad out the bottom, but dont quote me on that!
www.sas.org.uk
www.the-ace.org.uk
Offline tweed
« Reply #26 on: 18 February 2013, 14:41 »
Sounds a lot easier to just disconnect it
Offline Bellend
« Reply #27 on: 18 February 2013, 16:38 »
It is. Is technically illegal though.
I just did it as I didn't want to get the aircon done. If you do just remove it make sure it's in the open and you stay away. It can suffocate you pretty easy. Don't do it in a garage!
Halfords do regas kits now.
Offline murraymint
« Reply #28 on: 18 February 2013, 16:48 »
Sounds good Len!!! I was gunna try and do it without disconnecting the aircon anyways.  :laugh:
josh
« Reply #29 on: 18 February 2013, 20:06 »
I love the way people say just deconnect the AC pipes, the gas is deadly why mess about with it, get it degassed by someone that knows what they are doing.
