Author Topic: Quick question  (Read 3070 times)
Offline murraymint
Quick question
« on: 01 February 2013, 18:14 »
What's this on my inlet manifold? It was plugged in
My other manifold doesn't have the bracket for it
Josh
josh
Offline tweed
Re: Quick question
« Reply #1 on: 01 February 2013, 19:40 »
Didn't have that on mine  :huh: guess its a latter manifold some sort of sensor. Inlet temp to help with fuelling? As a guess
Offline Ess_Three
Re: Quick question
« Reply #2 on: 01 February 2013, 19:49 »
Nope.
It's the engine bay temperature sensor for the run-on fans as fitted to cars with Air Con (cars with the twin fans set-up).
..but gaining motorcycles.
Offline murraymint
Re: Quick question
« Reply #3 on: 01 February 2013, 19:51 »
Nope.
Ah bugger, so I can't use my other manifold then
josh
Offline Ess_Three
Re: Quick question
« Reply #4 on: 01 February 2013, 19:56 »
You could...
But you'll never have the fan cut in to cool things down.
This may not bother you...as not all 16vs have the functionality anyway.
Offline Screech16v
  • MK3 20vt AGU
Re: Quick question
« Reply #5 on: 01 February 2013, 20:00 »
I had this on mine 97 with aircon, allways wondered what it was,fans would sometimes kick in 20mins after switch off.
Offline murraymint
Re: Quick question
« Reply #6 on: 01 February 2013, 20:06 »
You could...
Does it take the reading from the manifold itself or from the engine bay? If its the later I could try find somewhere to put it. I'm guessing its the first tho  :undecided:
josh
Offline dragongreengolfgti
  • my golf gti mk3
Re: Quick question
« Reply #7 on: 01 February 2013, 20:07 »
i havn't noticed this and i have air con i will check tomo  :smiley: hopefully my spare has it lol
Offline murraymint
Re: Quick question
« Reply #8 on: 01 February 2013, 20:11 »
Yh yours as it mike
josh
  • my golf gti mk3
Re: Quick question
« Reply #9 on: 01 February 2013, 20:15 »
very true  :sad: i shall dig the the polished one out the shed tomo hopefully it has too :D
