Author Topic: intake manifold / fmic Q  (Read 3136 times)
Offline rfn_hodgson
« on: 28 January 2013, 13:06 »
hello fellas :)
i am wanting to get a front mount intercooler but i dont like the pipe going over the MAF if you know what i mean but i have seen some engine bays and the charge pipe comes round on the left then down and the boost pipe from the cooler to the intake manifold is on the right and the manifold is the other way round to my auq.
best to decibe is on here :
http://www.ttforum.co.uk/forum/viewtopic.php?f=2&t=173902
now can i just swop the manifold over and the charge pipe and bing badda boom add some silicone pipes and the cooler and pow i have a neat engine bay :D ??
« Last Edit: 28 January 2013, 13:09 by rfn_hodgson »
VW Golf MK4 1.8 Turbo AUQ 203 BHP-more now :) , ultimate vacuum delete, Forgre 007p-new piston, Oil catch can, s3 boost set up, FMIC, silicone TIP, full turbo back exhaust, stage 1 map, lowered on V-maxx coilovers  audi tt Quattro alloys
Offline rockmonkey69
Re: intake manifold / fmic Q
« Reply #1 on: 28 January 2013, 13:18 »
The thing is the k04 turbo sits a little further up from where the k03/s variants would.
Offline Dalo Harkin
« Reply #2 on: 28 January 2013, 14:22 »
I have done this on mine, decided it was easier
Offline rfn_hodgson
« Reply #3 on: 28 January 2013, 16:49 »
so what exactly is needed then buddy??
Offline Dalo Harkin
« Reply #4 on: 28 January 2013, 17:09 »
I went with the S3 inlet and the K04 charge pipe, do you mean in terms of what I/C pipes?
Offline rfn_hodgson
« Reply #5 on: 28 January 2013, 17:18 »
well for a start did you have to modify the charge pipe to be able to fit how did you connect to the turbo
and did you have to modify the fuel rail and extend any wiring??
Offline rfn_hodgson
« Reply #6 on: 28 January 2013, 17:20 »
and what engine code s3 did you take the parts off :)
Offline Prawny
  • R-tech power!!!
« Reply #7 on: 28 January 2013, 17:41 »
The parts you're thinking of can be found on APY/APX/AMK/BAM engines. there may be others but those are the ones that spring to mind quickly.
You'll have to extend the throttle body wiring to meet, and sort out re-plumbing your servo hard line as well.
The ko4 charge pipe also won't mate up to the ko3 properly, as the ko4 sits much further towards the passengers side. Not sure how to overcome this as I've not done one before.
All the above is assuming you have an AUM/AUQ as well, as it won't work for an AGU.
For the hasstle, I'd just have a pipe going over the engine bay.
Offline paultownsend
« Reply #8 on: 28 January 2013, 17:49 »
I have seen a few clever installs that run the ic poor from the turbo under the TIP.
Think this uses x2 90' silicone bends. But I reckon this would greatly reduce flow.
I read in a tuning guide that every bend in an intercoolers Tracy reduces flow by X%. A 90' being the worst.
