Author Topic: K03 to K03s  (Read 5398 times)
Offline Dalo Harkin
K03 to K03s
« on: 28 January 2013, 12:35 »
Getting my K03s on tomorrow, but I currently have a stage 1 carbon remap, do I need to do anything in order for it to run ok?
I cant get it mapped for at least another week, but may still need to potter around here and there in it
also from my spec, what 'should' I get from a stage 2 remap?
Offline mcgee9t2
Re: K03 to K03s
« Reply #1 on: 28 January 2013, 12:37 »
99% sure it should be ok to potter around in, doubt youde be getting max power out of it but should be fine afaik
Offline Dalo Harkin
Re: K03 to K03s
« Reply #2 on: 28 January 2013, 12:40 »
do I need to unplug anything or should it be ok, can I give it the beans or best to lay off  :undecided:
Offline Nino
Re: K03 to K03s
« Reply #3 on: 28 January 2013, 13:08 »
Not to sure with your main question however I have been researching "what to do" when it comes to stage 2 remaps.
The things I have found that should be done are as follows:
  • clutch and flywheel.
  • upgrade all pipes to silicones.
  • upgrade the DV.
  • upgrade injectors.
  • upgrade the air filter to a higher performance panel filter or induction kit.
  • advisable to upgrade the exhaust.
I'm sure there are bits I have missed. Others will add I'm sure :)
Current - MK6 GTi Edition 35
Offline Prawny
  • R-tech power!!!
Re: K03 to K03s
« Reply #4 on: 28 January 2013, 13:10 »
Whilst generally it's not advised to thrash it when a bigger turbo is fitted, in the case of a st1 AGU going from ko3 to ko3S I've generally found them to be fine.
Depending on how aggressive your st1 is you may find it misfires a bit under boost, so be careful if that's the case until it's mapped, but 9/10 times they run just fine with a ko3S bolted straight on.
Offline Granta Gti
Re: K03 to K03s
« Reply #5 on: 28 January 2013, 17:20 »
Mines ARZ and went from k03 to k03s and ran it for a month no problems! I have an ebay3" system and standard smic and using a formula it is running aprox. 226 bhp not been on a dyno yet.
Offline Dalo Harkin
Re: K03 to K03s
« Reply #6 on: 28 January 2013, 22:30 »
was your k03 mapped?
Offline Granta Gti
Re: K03 to K03s
« Reply #7 on: 28 January 2013, 23:11 »
Offline MattyV6
  • Mk4 .:R32 - The Black Destroyer
Re: K03 to K03s
« Reply #8 on: 29 January 2013, 12:38 »
My old 1.8t Anniversary had the ko3s as standard as was mapped to a safe 210bhp. Only downside was the wheel spin in the damp or wet. It was shocking.
Not in any way standard :) Dyno Dynamics RR - 280bhp
Offline Dalo Harkin
Re: K03 to K03s
« Reply #9 on: 29 January 2013, 12:44 »
Well when I have my map I am hopefully looking at 225-230bhp
