Author Topic: wellycooler - N75 + DV take offs  (Read 8008 times)
Offline pickles
  • Next!!!
« on: 21 January 2013, 23:52 »
is it adviseable to retain the stock charge pipe when doing the wellycooler so as to retain the original take offs for the N75 and DV valves.
cant see any clear explanation of how the valves are connected after the install apart from the mentioning of taps n stuff. any info appreciated :)
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline Dalo Harkin
Re: wellycooler - N75 + DV take offs
« Reply #1 on: 22 January 2013, 08:00 »
depends which way you want to do it, the stock charge pipe is a smaller diameter than the rest of the wellycooler setup, I went the K04 charge pipe way but this also involves changing the inlet mani.
I have seen people use a straight piece of tube and getting the takeoffs welder on to that
Offline pickles
  • Next!!!
« Reply #2 on: 22 January 2013, 09:12 »
wana do the welly cooler setup keeping the inlet manifold in the same orientation, just baffled a to what happens to the N75 and DVs, do i need to purchase a seperate pipe with take offs which is not shown in any of the install threads, dont wana fart about drilling, might just TOYO KIT it.
Mapped
Nearly S3 time  :)
Offline paultownsend
« Reply #3 on: 22 January 2013, 09:32 »
Im interested to see how your k03 will perform with the wellycooler and associated 2.5" piping.
But looking at your sig you'll be going hybrid.
I have no plans to go above k03s, if at all. So I may go with 2.25" piping and intercooler inlet/outlet.
If so I wil be using the OE charge pipe. Or maybe even a 1.8t mk2 Ibiza charge pipe.
Offline pickles
  • Next!!!
« Reply #4 on: 22 January 2013, 09:57 »
plans change all the time lol, notime to go hybrid  :laugh:, got a k03s en route so gna whack that on.
Mapped
Nearly S3 time  :)
« Reply #5 on: 22 January 2013, 09:59 »
So will the welly and piping be too big?
I can only muster a measly 16psi of boost  :grin:
Offline pickles
  • Next!!!
« Reply #6 on: 22 January 2013, 10:08 »
what the 2.5 or 2.25, il be going 2.5.
Mapped
Nearly S3 time  :)
Offline Dalo Harkin
« Reply #7 on: 22 January 2013, 12:18 »
im running a K03 and wellycooler on mine with 2.5" piping and its fine, there is a small amount of lag, but nothing a K03s and stage 2 wont sort out  :cool:
Offline Prawny
  • R-tech power!!!
« Reply #8 on: 22 January 2013, 12:31 »
the 'wellycooler' and 2.5'' pipes will be fine on a ko3S.
DV and N75 are down to you really mate, the N75 is dead easy, just using a 6mm brass hose tail with a 1.8th thread drilled and tapped into a pipe and sealed up with chemical metal. the dv take off at 25mm is a bit harder, you can either use a cold side relocation kit, or get someone to weld on a 25mm stub for you.
I've seen people use the original charge pipe turned round  and joined with a straight coupler to face up and forward to amtch the wellycooler pipework, I think the stock charge pipe is 54mm, and being directly after the 2'' turbo outlet it shouldn't be a big problem using it for that short length.
Offline pickles
  • Next!!!
« Reply #9 on: 22 January 2013, 12:44 »
exactly what i was after m8,thanks alot.
alot of the ebay kits iv seen do a pipe with th 25mm stub, cant these be sourced seperate
Mapped
Nearly S3 time  :)
