Author Topic: Golfyste's road legal mk4 "project track car"  (Read 280534 times)
Offline golfyste
  • Project track car
Re: Golfyste's road legal mk4 "project track car" *She's on the road!*
« Reply #290 on: 10 November 2013, 00:00 »
Ktm 400exc dude  :cool:
If you go back to page 12 I posted a few photos of it as I had to remove the engine!
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #291 on: 10 November 2013, 11:40 »
So does this mean the K04 wasn't at fault?
Offline golfyste
  • Project track car
« Reply #292 on: 10 November 2013, 11:43 »
Yeah I think the original 001 was ok as it was the catch can and venting the breather to atmosphere that solved the problem!
Now stuck as to weather I fit the original 001 to the rebuilt engine as the Ecu already has a decent map in it and will be better for running the engine in ir do I fit the bigger new 001 and run on actuator pressure to run the engine in until I get it mapped!?!?  :huh: :undecided:
Offline smithyvr6
« Reply #293 on: 10 November 2013, 15:49 »
Just had a look at page 12 mate...that was lucky  :shocked: ive got a 2009 yzf 250 and a 1998 rm 250.
Offline golfyste
  • Project track car
« Reply #294 on: 10 November 2013, 15:51 »
[/quote/]
Just abit!!  :laugh:
Very nice! I need to get out on mine a but more often I think haha
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #295 on: 10 November 2013, 16:59 »
bit of a dilemma then bud. Personally I'd stick with the newer one...
Offline Diamond Hell
  • Opinions я Us
« Reply #296 on: 11 November 2013, 08:47 »
Do the breathers on these engines block at all?  Worth having a poke around before you rip the motor out and get all heavy on it.
The risk with your Discovery is that you'll get further from safety before it beaches itself.  :grin:
Also you have a winch on the front, which is handy if you need to recover someone else, but rubbish if you've driven into something you want to get out of cos your only option is further forwards.  :wink:
Offline golfyste
  • Project track car
« Reply #297 on: 31 December 2013, 18:23 »
Ok I've not updated this I'm ages!
Mainly because I've been crazy busy with work and family etc and also been working on/fixing the disco
....but that's another story
BUT! It's time to get back on this!
Just started work on the engine
Got it in the garage
Stripped the loom off and tagged everything up
Removed the egr and hard pipes that won't be needed and started attaching my home made engine stand bracket
Just need to make another bracket for the stand attachment and then I can start stripping it down!
Yeah I think ok going to dude just gonna drive it on actuator pressure until it's mapped!
DH - the breathers do block up but mine were clear but either way I already had £600 worth of rods and other bits for he rebuild so it's being done anyway haha
« Last Edit: 19 January 2014, 22:42 by golfyste »
Offline golfyste
  • Project track car
Ok update time!
I've finally had some time to do some work on the engine!
Got it all up onto the home made stand...
Started the strip down process which included removing all the water lines, fuel rail and injectors, oil cooler etc etc
I bagged and tagged everything as I removed it just to make things easier
I got to this point and got stuck as I needed the VW ribe tool for the headbolts which I had ordered and I also couldn't (and still can't as the compressor has packed up!) remove the crankshaft pulley bolt!
A few pics of a couple of bits I ordered...
I then set around removing and stripping the head down!
The pistons look pretty horrible! Good job a have some more haha
My little set up
And stripping the large port head....
All bagged up
Removing the valves
All removed and cleaned up!
The next step for the head is to try find somewhere to acid dip it to get it back like new and also get rid if all the carbon build up!
I also need to move onto the lower block and try get the crankshaft bolt out so I can strip the pistons and rods out and then clean up and paint the block and also hone it before starting to build it back up!
Any suggestions or anything are welcome
  • Opinions я Us
Send it to JNL Racing to be properly breathed on.  :cool:
