Author Topic: rear indicator wiring  (Read 2052 times)
Offline Dalo Harkin
« on: 14 January 2013, 12:43 »
Hi all,
I have red rear clusters and get red when the indicators are on  :whistle:
now I have the LED bulbs and resistors needed to stop the hyper flashing, my question is does anyone know which colour wire the resistor needs adding between?
Offline Dalo Harkin
Re: rear indicator wiring
« Reply #1 on: 15 January 2013, 12:59 »
anyone?
Offline Ralphy_GTI
« Reply #2 on: 15 January 2013, 13:21 »
it would be the input wire i guess but im not sure of the colour?
Golf Mk3 GTI - Gone but never forgotten!
Golf Mk4 TDI - Back from the dead!
Offline beppe2672
« Reply #3 on: 15 January 2013, 18:53 »
Should be black/white drivers for the left indicator and black/green for the right. What size resistor are you using as I've just ordered led indicator bulbs myself.
1999 1.8t AGU, KNN Panel filter, Smoothed air box, Custom CAI, Forge 007 dv, REVO stage 1, 3" eBay TBE. Audi TT quickrack.
To come - A DIY hybrid K03 and a whole lot of supporting mods!
Offline Dalo Harkin
« Reply #4 on: 15 January 2013, 20:06 »
can't remember but will have a look and let you know, there was a post on another forum telling what size resistors, but not what wiring you needed to add them into
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 15 January 2013, 20:16 »
There are spare terminals on the back of the bulb holder, if you trace the tracks you can add a resistor to the terminals rather than splicing into the wires. I've done this and it works a treat
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 15 January 2013, 20:17 »
Oh and you can also mod your hazard switch if you don't want to use resistors on the wires :wink:
Offline beppe2672
« Reply #7 on: 15 January 2013, 20:38 »
just done some math, gonna need a 6ohm resistor capable of at least 25w, probably 50w to be on the safe side.
Offline Dalo Harkin
« Reply #8 on: 16 January 2013, 12:32 »
is it not easier to just add in between the wires? I believe it is just when you indicate with LED bulbs and dont have resistors they flash as if one is blown
do you have any pics of the ones you did?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #9 on: 16 January 2013, 12:38 »
Trouble is with adding the resistor to the wires is that you have to add them across the positive and negative so you'll have to pull the covering off the loom to get to them.
Yeah it just flashes quicker or worst case not at all. All of my bulbs are LEDs now so I had to add a resistor as well as modding my hazard switch
I'll get a pic later
