Author Topic: What have you done to your Mk6 today then?  (Read 1634627 times)
Offline david25
Re: What have you done to your Mk6 today then?
« Reply #3240 on: 06 June 2024, 07:24 »
Car back after a £250 bill, they fitted 06h 103 495aj the part costing £100
Reading around the revision you need is dependent on build date, before or after 13 June 2010
Now = 2011 MK6 GTI - Reflex Silver
Past = 2006 MK5 GTI - Tornado Red and Solid Black
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #3241 on: 06 June 2024, 11:01 »
 :smiley: I know when I got mine the dealer said it was chassis number dependent. Did mine a few years ago and was about £80 back then iirc.
« Last Edit: 06 June 2024, 11:03 by Snoopy »
Current Garage:
35+ years of GTI ownership.
Offline david25
« Reply #3242 on: 20 June 2024, 19:28 »
Quick update, car runs much better! I wonder if the fault was present for far longer before the split got large enough to hear.
Next question,
Water in in the rear footwells,is this the inner panel rubber seals getting old?
Bonnet liner sagging, are these really glued? I thought the liner was rigid and just held in by the tabs? Will they have to glue a replacement in?
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #3243 on: 21 June 2024, 20:25 »
Footwells normally door inner seals. Bonnet liner is age and heat cycles it sags sadly.
Current Garage:
Offline Nino
  • Insta - F6UGA
« Reply #3244 on: 23 June 2024, 19:06 »
Fitted my private short numberplates today I removed the numberplate plinth and decided to run without it.
My god, it was paintful to see so many holes :(
For the big holes, I found these caps in my garage so rubbed them down and used touchup paint to colour code them.
For the small screw holes, honestly why can't people just use pads  :shocked:
I used some flexiable panel filer to fill the holes then wipe over with a wet sponge, I will use my touchup paint over it tomorrow.
This will do until I can afford my bumpers to be professionally repaired I guess.
Current - MK6 GTi Edition 35 - Candy White - 3 door.
Offline david25
« Reply #3245 on: 24 June 2024, 18:19 »
Sorry, I mean to say, how do they fit a replacement? Does it just fit into the tab arounds the edge of the bonnet and/or stuck with something in the middle?
Offline joe6
« Reply #3246 on: 25 June 2024, 08:50 »
Should fit with the tabs and several 'buttons' in the middle. The are holes for these in the bonnet ribs.
Offline david25
« Reply #3247 on: 11 July 2024, 14:30 »
Annual service today, they recommended
Front discs and pads £575
Rear discs and pads £444
Oil sump £360
After seeing the video, I agree on the rear discs and oil sump
Anyone had these bits replaced recently as a price check?
Thanks
Offline Nino
  • Insta - F6UGA
« Reply #3248 on: 11 July 2024, 22:46 »
I bought Brembo UV coats Discs and pads for the front and rear for my GTi and used Apec pads, did the work myself and cost no-where near that.
Offline david25
« Reply #3249 on: 15 August 2024, 18:54 »
Oil sump replaced today at the main dealer, the local specialist I used for the PCV valve (see earlier posts in this thread) was quoting £611 against the main dealer price of £380
This is the old one and let me know if you want the parts list, you'll need replacement bolts and "special" sealant
