Author Topic: What have you done to your Mk6 today then?  (Read 1622416 times)
Offline david25
Re: What have you done to your Mk6 today then?
« Reply #3230 on: 30 March 2024, 12:35 »
Failed MOT with a cut tyre, £220 later (2 x AS6) the same day it passed
Now = 2011 MK6 GTI - Reflex Silver
Past = 2006 MK5 GTI - Tornado Red and Solid Black
Offline joe6
« Reply #3231 on: 01 April 2024, 13:28 »
Just completed a pre-MOT check. Drop link bushes split. Another job to do!  :sad:
Offline david25
« Reply #3232 on: 14 May 2024, 09:40 »
Replaced the original orange dipstick with the new yellow version after one of the small tabs broke.
I note the orange version has problems with becoming brittle.
Offline JSYGTI
« Reply #3233 on: 15 May 2024, 07:47 »
Took mine for a spin as it had sat for a week while I’d been on holiday, spent 30 minutes finding out where a rattling noise was coming from  :grin:
Offline david25
« Reply #3234 on: 29 May 2024, 15:34 »
Anyone know if an auxiliary belt problem sounds like an old fan belt slipping? Like a fast whirring, screeching that goes up and down with engine load/speed?
I waiting for a diagnostic tomorrow morning.
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #3235 on: 30 May 2024, 15:21 »
Could be,
Ac pulley I've heard of seezin.
Could be a number of things though.
It's not coming  from the pcv valve is it?
Current Garage:
35+ years of GTI ownership.
Offline david25
« Reply #3236 on: 31 May 2024, 09:30 »
Could be,
When I opened the bonnet it seems like the noise from the pulley side of the engine, also on the way to the garage this morning I can add lumpy idle with the rev counter unsteady at the traffic lights. Also, it runs for a fraction when you turn off the engine.
Hopefully the specialist can identify belt, pulley, or PVC this morning.
Offline david25
« Reply #3237 on: 31 May 2024, 11:44 »
Garage thinks its the PCV valve, can't get the part until Monday, with the diagnostics its £250
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #3238 on: 31 May 2024, 12:43 »
If its happened for a while check you don't also have an oil leak from between the gearbox and engine under the car. When the pcv valve goes and the pressure rises it trys to vent at the weakest point. Sadly this often ends up being the rear main  seal and it fails.
Current Garage:
Offline david25
« Reply #3239 on: 31 May 2024, 19:00 »
It happened suddenly on a journey this week, didn't get to work, turned back and went home. Of course it could have been failing for months without making a noise?
Hopefully there is no main seal failure, but thank you for letting me know. I will call the garage and ask them to check when they fit it on Monday.
