Author Topic: 1400 abd running issues  (Read 1095 times)
Offline dubpirate
« on: 30 December 2012, 14:44 »
ok so when the car starts with throttle (from cold )
it struggles to rev up
if it slightly blip the throttle a couple of times it will die (like its being choked )
any ideas
Offline itavaltalainen
Re: 1400 abd running issues
« Reply #1 on: 30 December 2012, 15:37 »
check the air intake connection under the injection unit.
probably cracked..should be p/n    030129765G.
Offline dubpirate
« Reply #2 on: 30 December 2012, 17:22 »
could this also be responsible for the throttle required to start ?
« Reply #3 on: 30 December 2012, 18:10 »
in short yes...
long version: if your flange is cracked it will suck in air the ecu does not know about i.e. leaning the mixture.
when you play with throttle the injector will inject more fuel; it still sucks in air from cracks but the vacuum pressure is lower  behind the throttle when it's open, so will suck in less from the cracked flange. hence it's running better.
make sense?
Offline dubpirate
« Reply #4 on: 31 December 2012, 14:53 »
how do I remove the flange pal
today I got as far as removed the cap and intake ontop cleaned the carb its self (if it is a carb) then I saw 4 more 10mm bolts is this all it is to remove the flange obv after disconnecting pipes and connectors from the carb
any how it started pissing it down so had to put it back on and come inside
just wanderd if im on the right tracks cheers
