Author Topic: Help: ASZ turbo does not fit my ASZ engine?  (Read 3215 times)
Offline VW_UK
  • 2000 (X) Mk4 TDI S for sale. £2250
« on: 29 December 2012, 17:38 »
Ok, a bit confused. I've read a number of times that a ASZ 130 tdi turbo would fit to an Ibiza/ golf/ A3 however I have bought one recently but seems to have a different outlet position to the one that's been removed:
One removed: notice the outlet (where turbo pipe fits) top left
ASZ replacement: outlet top right
Can someone enlighten me please? Is one of them not an ASZ or there different types?
Offline rio_gti
Re: Help: ASZ turbo does not fit my ASZ engine?
« Reply #1 on: 29 December 2012, 17:41 »
Can you not just undo the bolts and rotate it??
Offline VW_UK
« Reply #2 on: 29 December 2012, 17:44 »
Ok silly question, but would it be as simple as that?
Would I need to change any gaskets etc?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 29 December 2012, 20:27 »
no you won't need to change gaskets to do it. As Rio says it look like the compressor housing has been rotated for some reason
Offline VW_UK
« Reply #4 on: 29 December 2012, 20:43 »
Had a quick look and not sure which bolts to remove to rotate it...? :(
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 29 December 2012, 21:01 »
get some pics of the back of the compressor housing and I'll see if I can point them out
Offline beppe2672
« Reply #6 on: 29 December 2012, 21:02 »
If you have a look at the back of the compressor side you'll see 6 bolt with large washers on them, loosen these and you should be able to gently turn the compressor into the correct position, then tighten them back up of course!
1999 1.8t AGU, KNN Panel filter, Smoothed air box, Custom CAI, Forge 007 dv, REVO stage 1, 3" eBay TBE. Audi TT quickrack.
To come - A DIY hybrid K03 and a whole lot of supporting mods!
Offline VW_UK
« Reply #7 on: 29 December 2012, 22:25 »
Not the greatest pic I know but only one I have on my phone.
Bolts on left or right in the pic?
Offline beppe2672
« Reply #8 on: 29 December 2012, 23:07 »
if all the oil lines and stuff line up ok just the bolts on the right.
Offline VW_UK
« Reply #9 on: 29 December 2012, 23:22 »
Yes they seem to line up all ok. Will double check again but this was the only difference I noticed.
