Author Topic: Help: ASZ turbo does not fit my ASZ engine?  (Read 3217 times)
Offline JimBR
Re: Help: ASZ turbo does not fit my ASZ engine?
« Reply #10 on: 30 December 2012, 17:06 »
Not a turbo off a Passat/A4/A6 is it?
Offline VW_UK
  • 2000 (X) Mk4 TDI S for sale. £2250
« Reply #11 on: 30 December 2012, 21:33 »
It may be, although was told its off a golf
What difference does that make?
Offline JimBR
« Reply #12 on: 30 December 2012, 22:07 »
The engines are longitudnal not transverse, which may explain the difference in orientation.
Offline VW_UK
« Reply #13 on: 01 January 2013, 18:00 »
Ok, unfortunately another dilemma - had a closer look at the manifold and the bits highlight are in different positions. Does this mean it won't fit (even after being able to turn the turbo to the correct position)?
Red is replacement, blue is the one removed from the Ibiza
Offline asboGTI
« Reply #14 on: 01 January 2013, 18:44 »
Y not swap the manifolds over surely that would work
vw golf mk4 ARZ 1.8T pipercross panel filter, xenon headlights, JOMS coilovers, forge 007p with green spring, audi tt anti roll bar, 3inch ebay trubo back exhaust, COOKIES MONSTER STICKER(adds bhp I swear)
Offline VW_UK
« Reply #15 on: 02 January 2013, 00:06 »
Been told the pipe that connects to it is flexible so should flex to fit. Failing that I will do an EGR blank. £3 or £4 off eBay and better for the engine too.
Offline JimBR
« Reply #16 on: 02 January 2013, 09:07 »
Id do the egr blank personally. Id imagine it would need mapping out though?
Offline EsSeX dAn
« Reply #17 on: 02 January 2013, 09:15 »
depends what one it is. seeme the earlier ones are ok withit whereas the later ones tend to have a bit of a fit
i think i love you.....
Offline VW_UK
« Reply #18 on: 02 January 2013, 09:42 »
Why would they need mapping out?
Offline Rhyso
« Reply #19 on: 02 January 2013, 09:55 »
On later cars it throws up the engine management light and in extreme cases, limp mode.
