Author Topic: Thermostat Issue  (Read 3421 times)
Offline stfc_gti
Thermostat Issue
« on: 16 December 2012, 17:09 »
I have had an issue recently where my thermostat wasn't working, the temp gauge was always showing below 80, so ive had my thermostat and a few other bits replaced but now the temp guage gets up to 90 very nicely and sits there but after about 10 minutes it will rise and rise and get to about 110 and then depending on how fast I am going it will fluctuate between 95 and 110/115. (the faster I go the higher it goes) should I be worried the car is over heating or has my mechanic missed something?
Thanks in advance.
2002 1.8T GTI AUM, Standard (not for much longer)
Offline navmk4gti
Re: Thermostat Issue
« Reply #1 on: 16 December 2012, 17:32 »
Have u changed temp sender?
Offline stfc_gti
« Reply #2 on: 16 December 2012, 17:34 »
I do believe this was changed yes.
Offline Chris#101
« Reply #3 on: 16 December 2012, 17:53 »
water pump?
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline stfc_gti
« Reply #4 on: 16 December 2012, 18:01 »
water pump?
if it is, is it a big issue? having to commute I cant get to a garage until weekends
Offline navmk4gti
« Reply #5 on: 16 December 2012, 18:11 »
You got heat coming out when You put on your heaters? Sounds like temp sender which Is 13 quid. Water pump looking into £200+ :lipsrsealed: would not jump to that till all cheap options are Rulled out :wink:
Offline stfc_gti
« Reply #6 on: 16 December 2012, 18:27 »
I've just checked the invoice and the sender was changed too.
when I got into the car today, it did take a while for hot air to come out of the heaters.
Offline Dalo Harkin
« Reply #7 on: 16 December 2012, 18:53 »
it should do, but from reading your original post something is wrong with the thermostat
Offline stfc_gti
« Reply #8 on: 16 December 2012, 18:57 »
Even though it's been changed? I'll just have to drive her carefully and get her looked at again at next weekend.
Offline navmk4gti
« Reply #9 on: 16 December 2012, 19:10 »
Did dey use genuine parts?
