Author Topic: Thermostat Issue  (Read 3419 times)
Offline stfc_gti
Re: Thermostat Issue
« Reply #30 on: 31 December 2012, 10:42 »
Drove her properly for the first time since having her back, and temp gauge sits nicely at 90 degrees. Larvly!!!
2002 1.8T GTI AUM, Standard (not for much longer)
Offline xtetx
« Reply #31 on: 04 January 2013, 09:17 »
If you change the water pump, make sure it has metal teeth not plastic dude
New ones are made of a different composite so aren't as fragile as the old type. I'd rather the impellor break off than a metal one seize, I've repaired the damage that it can cause and it's not pretty
sweet! learn something everyday!
