Author Topic: Is my thermostat broke????  (Read 2313 times)
Offline Graham.Concept
  • Yellow Colour Concept
« on: 16 December 2012, 11:48 »
my gti was ticking over for a few minutes when thie top radiator hose blew off, emptying the coolant all over the engine. The pipe that came off is the big 1 from centre of the water flange. it has snapped the lip clean off inside the hose so ther no way the hose can go bak on. has this happened because its a really old part or because of a problem with thermostat  ??
I will get a picture up of the flange
MK3 <3
Offline tweed
Re: Is my thermostat broke????
« Reply #1 on: 16 December 2012, 11:54 »
its prone to cracking/warping
did your take a long time to get up to temperature?
did your car temperature ever go over 90 just before this happened?
« Reply #2 on: 16 December 2012, 12:00 »
i had been driving for maybe 15 minutes so temp was in middle of gauge wer it has never gone over before, i wasnt in the car when it happened it was ticking over maybe 10 yards away assoon as i herd the water and seen the steam i cut it out and pushed the car some wer safe, ineed to get car hom realy but cant run it till fixed :@
MK3 <3
Offline tweed
« Reply #3 on: 16 December 2012, 12:07 »
I think its just a old part that needs replacing.
 its common
« Reply #4 on: 16 December 2012, 12:16 »
could the car be strartd and drove maybe 100 yards like this my theory is yes because it wont b hot enough to need water by time im cutting it out, i need to get it home asap is this going to nakker my engine??
MK3 <3
VW BUSH
« Reply #5 on: 16 December 2012, 12:26 »
They break, especially cheap ones.
Both plastic flanges are about a tenner a pop, change them both
Offline tweed
« Reply #6 on: 16 December 2012, 12:52 »
I wouldn't drive it and longer than 2 mins and never go over 2500rpm
VW BUSH
« Reply #7 on: 16 December 2012, 13:03 »
Its his head gasket, he needs to learn :grin:
« Reply #8 on: 16 December 2012, 13:26 »
what do i need to learn???
MK3 <3
Offline itavaltalainen
« Reply #9 on: 16 December 2012, 13:37 »
Wouldn't really start it as all water left in the engine will come splashing out  :whistle:
If it is only 100 yards then first just drain all so it doesn't splash about everywhere.
