Author Topic: Water leak. Help still needed  (Read 1787 times)
Offline brejner
« on: 14 December 2012, 20:34 »
Evening all.
Just wanted to get some more advice. I have had all the outer door seals changed and the 2 front outer lower door seals changed and I still have a leak in the rear passenger footwell after this weeks down pour. The passenger seals have not yet been changed but they seem ok. Any ideas would be great. Sorry to retread old ground.
Thank you for your help.
Offline GTi_James
Re: Water leak. Help still needed
« Reply #1 on: 15 December 2012, 09:47 »
sunroof?
Offline harlemex
« Reply #2 on: 15 December 2012, 15:10 »
rear light seals?
Offline dstv
« Reply #3 on: 15 December 2012, 15:54 »
I had the same issue a while ago and after 3 weeks of struggling, I found that the leak was coming from the pollen filter BUT....I had the filter and panel replace because I thought it was the reason but the leak was coming from the base of the pollen filter unit.
The leak ran down the front of the car under the carpet and stopped in the rear passenger foot rest :angry:
this confused the crap out of me but a tub of silicone and Vaseline sorted it out in a way. That was my experience
2000 GTI 1.8t AGU, neuspeed airfilter,Forge 007 dv, R-tech stage 1 remap, Silicone TIP,3" exhaust system, K03s turbo and a empty wallet.
Offline brejner
« Reply #4 on: 15 December 2012, 22:07 »
Cheers guys. Have tried to unblock the sunroof drain with washing line wire. Poured water down but not coming out of the nipple. Any ideas how else I can do this please
Offline GTi_James
« Reply #5 on: 16 December 2012, 19:33 »
check maintenance, i did a right up of sorts, pretty straight forward  :wink:
Offline djmagpie
« Reply #6 on: 16 December 2012, 22:19 »
i had water building up in my passager side rear footwell every time it rained and water leaking down the inside panel ov the c piller droped the headlinging down to find a tube had came off the rear sunroof drain pushed back on now no leak
1.8t agu,,Bora Vents,,Cai,,Vr6 clutch/G60 flywheel,,forge dump valve,,jom coilovers,,eibach front and rear arbs,, 15mm front 20mm rear spacers ,,3" downpipe & decat..sportex 4"oval exhaust
Offline brejner
« Reply #7 on: 19 December 2012, 23:03 »
Cheers guys. James - I tried the washing line thing but it wouldn't come out of the nipple. When i poured water it came out of the other side.
Dj magpie- how do I do your thing. Please could I have the idiot guide. Cheers.
Offline GTi_James
« Reply #8 on: 20 December 2012, 09:07 »
have you cleared the nippled out as squeezing them dont do anything but get rid of the loose crap in there, you need to cut the crimp off the end and insure that the rigid pipe is not loose on the internals
Offline brejner
« Reply #9 on: 20 December 2012, 13:23 »
Cheers james. Have cut the crimp off. I have noticed that there is a lot of water under the door rims. Have had the rubber door seals replaced though?
