Author Topic: Water leak. Help still needed  (Read 1798 times)
Offline GTi_James
Re: Water leak. Help still needed
« Reply #10 on: 20 December 2012, 13:25 »
Cheers james. Have cut the crimp off. I have noticed that there is a lot of water under the door rims. Have had the rubber door seals replaced though?
another easy way of knowing it is the door nipples is if you take the ribbed rubber off under the nipple that connects the 2 and feel in the ribs to see if theres water collecting there?  :undecided:
Offline brejner
« Reply #11 on: 26 December 2012, 19:17 »
Thanks James. I believe I have located the leak. It seems to be overflowing from the door sill the thing is I have had the internal door seal changed but not the external one changed. Is this worth doing?  I have also read that it is worth taking off the  door panel and getting the bottom sealed. Can anyone recomend me someone in west London to do this please.
Offline GTi_James
« Reply #12 on: 26 December 2012, 19:52 »
its simple enough mate, and theres a write up on youtube as well
Offline brejner
« Reply #13 on: 11 January 2013, 09:29 »
Sorry for the constant posts - Could you link the video so I can see how to remove the door panel and also where to apply the silicone please - couldnt find it on youtube.
« Last Edit: 11 January 2013, 15:41 by brejner »
