Author Topic: Today, is the day....  (Read 4401 times)
Offline Nino
  • Insta - F6UGA
Re: Today, is the day....
« Reply #20 on: 24 November 2012, 10:14 »
Lol i got them both im sure they will both come in handy. Just hope they turn up by tuesday :D
Current - MK6 GTi Edition 35
Offline Nino
  • Insta - F6UGA
« Reply #21 on: 27 November 2012, 11:19 »
Right for the record it was 21mm, and today is round 2! wish me luck guys :)
Offline mcgee9t2
« Reply #22 on: 27 November 2012, 11:31 »
Good luck.
remember. if you cant get the strut out of the strut mount on one side (think drivers but cant remember) check the drive shaft. most people dont mention that you need to disconnect the drive shaft on one side as it catches on the sib frame. seems to only happen on some peoples golfs though :s
still easy enough. undo the bolt on the hub end. slip it out. Carry on as per before.
Offline Nino
  • Insta - F6UGA
« Reply #23 on: 27 November 2012, 17:56 »
Another no go. Its bloody stupid its like the JOMs are not ment to go on.
We got my old strut out nice a smooth, infact i was thinking this is too easy.
Then trying to het the jom strut in, that was another story.... No matter what i tryed i could only get it in half way, it was like the strut was to thick to fit in the cup, so then i removed the JOM and tryed the old strut and it went straight in....
Long story short, got my hair off, and put my old on back in.
Gunna ether sell the joms or pay someone to "somehow" fit them haven't decided yet.
Offline Nino
  • Insta - F6UGA
« Reply #24 on: 27 November 2012, 17:59 »
Oh and to top it off my abs light is now on.....
Offline mcgee9t2
« Reply #25 on: 27 November 2012, 18:19 »
Try copper grease on the bottom of the struts. and put a jack under the strutmount/wishbone and jack it up pushing the trut into the mount.
abs light. proberbly knoked one of the wires off the break
Offline Nino
  • Insta - F6UGA
« Reply #26 on: 27 November 2012, 18:35 »
Tired all that bud, even bolted the strut in place, and tired jacking the bottom into it, abs light turned off on the way hme
Offline golfyste
  • Project track car
« Reply #27 on: 27 November 2012, 19:42 »
Did you try cleaning the slot that the strut into using a flapping wheel on a drill??
If its 100% clean slip it in jack the hub up and while there is pressure spilt the hub with a 1/4" wratchet and extension and maybe tap it a little and should go in.
Offline rfn_hodgson
« Reply #28 on: 27 November 2012, 20:33 »
youll want some kind of impact gun to braek the grip of the nuts on the front top mounts
nah brute force did it for me = knuckle rash lol
VW Golf MK4 1.8 Turbo AUQ 203 BHP-more now :) , ultimate vacuum delete, Forgre 007p-new piston, Oil catch can, s3 boost set up, FMIC, silicone TIP, full turbo back exhaust, stage 1 map, lowered on V-maxx coilovers  audi tt Quattro alloys
Offline Nino
  • Insta - F6UGA
« Reply #29 on: 27 November 2012, 20:38 »
Didnt try that no, i dont understand why the standard shock goes in easy but aftermarket one wont?
