Author Topic: Today, is the day....  (Read 4429 times)
Offline golfyste
  • Project track car
Re: Today, is the day....
« Reply #30 on: 27 November 2012, 20:57 »
Didnt try that no, i dont understand why the standard shock goes in easy but aftermarket one wont?
probably over the years the original strut and never really moved so just fit together nicley where as your new strut isnt worn or whatever.
i feel the key to everything with cars is cleanliness!
weather it be strut, rear beam bushes, or just nuts and blots if its clean it will be easier!
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #31 on: 27 November 2012, 21:10 »
New powdercoat will stop it going in
Offline golfyste
  • Project track car
« Reply #32 on: 27 November 2012, 21:12 »
.....that's what I meant  :laugh:
Offline jamie1989
« Reply #33 on: 28 November 2012, 15:53 »
JOM's are easy to fit mate lol I would say I would come and do em but I have no bloody time.
As everyone has said clean the hub and copper grease the strut and with abit of force it will go in.
I am off next Wednesday and can help you if that helps.
I found that once halfway in the lug on the back of the JOM strut needed assisting in as it didnt line up properly and stopped the strut from going all the way in.
When you trying next? My mate in Cardiff can/will fit them in his own unit if you wanted?
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline Nino
  • Insta - F6UGA
« Reply #34 on: 28 November 2012, 17:00 »
Dam wish I read this this before.... Anyway I have book it in to my local marcanic one of his staff members owns a Transporter with coil overs/ BBS RS and has alot of exp in fitting Coilovers etc, so there doing it for me next week for £100 all fitted and lowered to 40mm inc tracking.
Current - MK6 GTi Edition 35
Offline jamie1989
« Reply #35 on: 28 November 2012, 17:33 »
Happy days
Offline Nino
  • Insta - F6UGA
« Reply #36 on: 28 November 2012, 18:04 »
At least its done then, next step is silicones :-) althou i have heared the TIP is an absolote nightmare to fit?
Offline Granta Gti
« Reply #37 on: 28 November 2012, 23:07 »
Yup  :sad: give yourself a couple of hours!
Offline jamie1989
« Reply #38 on: 29 November 2012, 09:26 »
A little advise take your silicone TIP to a motor factor and buy GOOD new jubilee clips.
Remove the olf TIP beaware of the bolt through the standard tip on the turbo unit as people forget about this and wonder why it doesnt come off. Remove everything from the top then work to bottom of the TIP.
-airbox
-maf
-N75
-DV
-Hocky puck thingy
-bolt through the tip
Then from the top of the car push the new TIP onto the turbo it may help if you have someone under the car to assist it on the turbo and tighten a jubilee clip. The reverse the above. It took me about an hour and half the first time taken my time. Some are stubborn due to the one time only clips etc but you SHOULD be fine mate.
 :smiley:
