Author Topic: modding 16v airbox  (Read 5206 times)
Offline tweed
Re: modding 16v airbox
« Reply #10 on: 07 November 2012, 10:40 »
I have 80mm cold feed. I cut a hole in the box then used the top part trumpet to put on the hole (cut down) so I could seal it with silicone and have something to fix the 80mm hose to.
got any pics?
No. I might take some later if your lucky
Offline vwwvgolf
« Reply #11 on: 07 November 2012, 16:44 »
Blanking plate over the warm air intake opening and remove the vacuum piping from the side.  I also took out the connection points  and filled the holes with rivets.
do you just leave the vaccum pipes hanging there or remove them completely???
Offline tweed
« Reply #12 on: 07 November 2012, 16:49 »
Bad idea opening up the airbox. Glen knows why.
You'll see why in Feb 2013.
Whats going down?
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #13 on: 07 November 2012, 17:44 »
I completely removed both vacuum hoses from the throttle body and bunged up the outlets so there was no air leaks.
« Reply #14 on: 07 November 2012, 17:45 »
Whats going down?
It'll be frigging cold for starters.
Offline Khare
  • The bear that khares
« Reply #15 on: 07 November 2012, 18:14 »
Whats going down?
It's why I'm not down on power on my latest run. I'll be remodelling a new airbox when I'm back from Brazil, a sealed box.
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #16 on: 07 November 2012, 20:54 »
waste of time doing owt to the airbox
i have a un molested one for sale if anyone needs one
I run a K&N relocated to outside the bay behind the bumper.. i find this is the best way to go.
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline tweed
« Reply #17 on: 07 November 2012, 22:32 »
Doesn't really matter if you have a inter cooler hanging out the bumper  :rolleyes:
Offline Screech16v
  • MK3 20vt AGU
« Reply #18 on: 07 November 2012, 23:09 »
Now this is what ive been thinking,is there any benefit having cold air feed on a turbo motor,as i thought the air would get very hot as it passes through the turbo anyway ,or does every little help?
Offline Ess_Three
« Reply #19 on: 08 November 2012, 01:20 »
Best way how?
I tried it...built a long CAI to the duct below the drivers side foglight and it made no difference.
On yours it may help...but on most it'll do nothing but add bling and noise.
The standard airbox (de-restricted) is as good as anything on a 16v up to 200BHP.
..but gaining motorcycles.
