Author Topic: modding 16v airbox  (Read 5224 times)
Offline technics100
modding 16v airbox
« on: 06 November 2012, 22:33 »
I have bought a spare 16v airbox for my ABF with the hope of getting a good cold air feed upto it.  I have removed all the gibbons from the bottom of the box.  I now have cut the air intake and now have a 65mm hole in the bottom off the box. Is that enough with a cold air feed? I'm going to remove the top tapered intake pipe and either bellmouth it or else cut it back.  What do I do with the wee sensor on the side of the airbox, the one with the brown and black pipes. Can I blank them and remove the sensor.
I have read the toyotek thread, but just not sure on cold air feed sizes..
1995 Twilight Voilet Mk3 GTi 16V 5 door
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: modding 16v airbox
« Reply #1 on: 06 November 2012, 22:52 »
Blanking plate over the warm air intake opening and remove the vacuum piping from the side.  I also took out the connection points  and filled the holes with rivets.
Offline whileoceanasleeps
  • patience comes to those who wait.
« Reply #2 on: 06 November 2012, 23:56 »
cut a big section out of the bottom for big deep breaths
Offline Ess_Three
« Reply #3 on: 07 November 2012, 00:20 »
Tremendous idea...
Open up a sealed and insulated airbox beathing cold air, and let the engine ingest as much hot air as it likes, what with air taking the path of least resistance and all.  :whistle:
Hacked about airbox = lots of noise.
Hot air = de-tuning.
..but gaining motorcycles.
« Reply #4 on: 07 November 2012, 00:55 »
the cut is on the cold air side away from the engine, and it didn't make any change to noise for me for some reason.. anyhoo i have a cone and shield now  :wink:
Offline Ess_Three
« Reply #5 on: 07 November 2012, 05:35 »
Go measure the temperature in the engine bay whilst you are driving - you'll find the temperature near the engine, and on the wing side of the airbox, are pretty much the same. Warm/hot.
I'm surprised it didn't give some noise...it usually does.
You have an opn cone now?
With a heatshield?
Offline tweed
« Reply #6 on: 07 November 2012, 08:40 »
I have 80mm cold feed. I cut a hole in the box then used the top part trumpet to put on the hole (cut down) so I could seal it with silicone and have something to fix the 80mm hose to.
« Reply #7 on: 07 November 2012, 09:20 »
With a heatshield?
yeah you're probably right about the air temp thing.. it was stock filter maybe that's why no noise. yeah got open k+n filter now with a 2mm steel heat shield (no insulation at the mo) and a couple of cold air feeds comin up from the bumper. might make a new shield tho cos it's a bit gappy around the edges so I think it's lettin some hot air through
« Last Edit: 07 November 2012, 09:22 by whileoceanasleeps »
« Reply #8 on: 07 November 2012, 09:23 »
got any pics?
Offline Khare
  • The bear that khares
« Reply #9 on: 07 November 2012, 09:55 »
Bad idea opening up the airbox. Glen knows why.
You'll see why in Feb 2013.
