Author Topic: Need some advice on sill welding  (Read 6466 times)
Offline Danny171
Re: Need some advice on sill welding
« Reply #10 on: 05 November 2012, 15:17 »
Right, rebuild the lip it is then, will take some photos tonight and put them on,
Offline Bellend
« Reply #11 on: 05 November 2012, 15:54 »
I've just had to do a huge load of welding on my girlfriends Ka. Pretty easy once you get going, I personally covered the welds in red oxide and seam sealer then fibreglass, filler and primer and paint.
MOT tester said he couldn't even see where it had been welded and there was A LOT of welding done!
Where all my moneys went.
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #12 on: 05 November 2012, 18:14 »
When i did mine I cut out the rot and reenforced the inner sill right down to the lip while I could get access to it. Got some cheap non oem sills of ebay and cut out the bits that I needed and welded them flush, no over lapping edges. Looked invisible and could be jacked up on sill afterwards.
Offline Danny171
« Reply #13 on: 05 November 2012, 18:37 »
What sort of steel did you use to build up the jack area?
Offline Gti_Jamo
« Reply #14 on: 05 November 2012, 18:46 »
Was 1mm thick stuff. Bought it off ebay lol.
Offline Danny171
« Reply #15 on: 05 November 2012, 21:03 »
As you can see the lip is totally rotted away, got some good thick steel to plate over now, just unsure on how to build the middle bit of the inner sill, to give it strength to jack from.
Suppose i am just gonna make it up as i go
« Last Edit: 05 November 2012, 21:11 by Danny171 »
Offline whileoceanasleeps
  • patience comes to those who wait.
« Reply #16 on: 05 November 2012, 21:48 »
how about some triangular ish pieces welded inside at 90 degrees
Offline Danny171
« Reply #17 on: 05 November 2012, 22:20 »
Gonna get it all cut out, see properly what I'm up against.
Might strengthen the jack point with bit of 20x20 box section, plate over it all, then weld a strip of 35x5 flat bar to replicate the lip
Offline Screech16v
  • MK3 20vt AGU
« Reply #18 on: 05 November 2012, 23:30 »
35x 5  :undecided: mk3 is heavy enough  :laugh: , i would probably do something like this
« Last Edit: 05 November 2012, 23:32 by Screech16v »
Offline Danny171
« Reply #19 on: 06 November 2012, 07:08 »
Great diagram, makes it look so easy!!, on my pictures, no2, you can see a central strengthen piece that comes down vertical to make the lip three pieces of steel, do you follow me?? Hard to describe
That's the bit that's worrying me
