Author Topic: Need some advice on sill welding  (Read 6437 times)
Offline Danny171
Re: Need some advice on sill welding
« Reply #30 on: 11 November 2012, 17:07 »
Well  when I noticed the drain bung rotting , it was so much easier to take seat out, fold carpet back, cut out rot and cut in a plate and get a nice weld in, I left it all out When welded sill up, and it only burnt a small amount of paint from inside.
But to be honest, took about 3 minutes to take seat out,and the same for interior trim and carpet
VW BUSH
« Reply #31 on: 11 November 2012, 17:41 »
I would still bin the widow maker and buy a proper jack, it will not be as strong and they are crap death jacks anyway :grin:
Offline tshirt2k
  • Been there...Done that...
« Reply #32 on: 11 November 2012, 18:30 »
Yes mate i know what you mean,well depending on how much rot/metal you have to remove access may be a bit tricky but doable,i thought maybe something like this,i would probably make a tool or two to help form the steel.hope this gives you some ideas  :wink:
Good diagram here. :cool: I did the same although the angle piece needs to be a thicker gauge as it is on the original car.
Ideally it should look like the original. And dont jack on the sills again.
« Last Edit: 11 November 2012, 18:41 by tshirt2k »
Mk3 ABF 16VT Megasquirt V3
Offline Screech16v
  • MK3 20vt AGU
« Reply #33 on: 11 November 2012, 18:43 »
Nice work mate , are you good at everything  :grin: lol
Offline Danny171
« Reply #34 on: 11 November 2012, 18:47 »
It came to me in this state, I have a snap on trolley jack , wouldn't get underneath it on something I didn't trust
Offline tshirt2k
« Reply #35 on: 11 November 2012, 19:09 »
I try  :laugh:  :grin:
Considering how it started.
On a side note. You may want to check all the bungs down the length of the sill. Most of mine had rot and the rust creeps under the underseal and you can tell.
Then you can weld them up or use them to squirt underbody wax inside.
« Last Edit: 11 November 2012, 19:18 by tshirt2k »
