Author Topic: Need some advice on sill welding  (Read 6449 times)
Offline Screech16v
  • MK3 20vt AGU
Re: Need some advice on sill welding
« Reply #20 on: 07 November 2012, 20:42 »
Yes mate i know what you mean,well depending on how much rot/metal you have to remove access may be a bit tricky but doable,i thought maybe something like this,i would probably make a tool or two to help form the steel.hope this gives you some ideas  :wink:
Offline Danny171
« Reply #21 on: 07 November 2012, 22:15 »
Thanks for your time with the diagram, I did a little cutting back tonight, just to get a better look at what I need to do.
Now I have cut off the old lip,( it was all bent and twisted through bad jacking I presume) it actually looks a lot easier than I thought. I will be doing it just like the diagram .
Just need to give it a proper tidy up, gonna weld it Saturday if weather is fine, will upload some photos :smiley:
Offline Screech16v
  • MK3 20vt AGU
« Reply #22 on: 07 November 2012, 23:02 »
No probs mate,it will be a breeze once you get going,just make sure you cut back to good metal, welding rust is just crap  :rolleyes: ,cereal cardboard templates are your friend  :wink:
Offline Len
« Reply #23 on: 08 November 2012, 12:59 »
If its angle you need have a look at B&Q as they do nice bits of angle.
www.sas.org.uk
www.the-ace.org.uk
Offline Danny171
« Reply #24 on: 10 November 2012, 20:13 »
Full day welding and cutting, strengthened the jack point, plated over the lot, made a new lip
Found new hole around drain bung so plated that up while i had the seat and carpet out
Looking for a new welding mask now, as dropped the jack, and the car squashed my speedglass :embarrassed:
well easier than i imagined, just hard on the neck welding upside down :sad:
Offline Screech16v
  • MK3 20vt AGU
« Reply #25 on: 10 November 2012, 20:21 »
Looks solid mate  :cool: ,that speedglass is goin to cost ya!
Offline Danny171
« Reply #26 on: 10 November 2012, 20:25 »
Cheers mate
Same next weekend on passenger side :sad:
Gutted about the speedglass,oh well :cry:
Great tip with the cereal box, worked a treat, saved a lot of work :cool:
Offline Screech16v
  • MK3 20vt AGU
« Reply #27 on: 10 November 2012, 20:36 »
Yeah makes it loads easier,at least you will have a solid motor when your done  :smiley:
Offline whileoceanasleeps
  • patience comes to those who wait.
« Reply #28 on: 11 November 2012, 12:54 »
nice work, is it necessary to take out seat and carpet as you did?
Offline Screech16v
  • MK3 20vt AGU
« Reply #29 on: 11 November 2012, 14:16 »
Allways better to be safe than sorry  :wink:
