Author Topic: Need help with electric side of engine swap. And now AC  (Read 2622 times)
Offline tweed
I've asked before but never got a answer.
I'm gonna put the vr lump in my gti because, I can't sell the vr as a car without taking a huge loss. (Keeping the gti lump)
So I have everything I need and can do it easily but here is the question.
Will I be able to keep the standard gti laser alarm with the vr6 loom?
The vr6 has a after market alarm and I don't want to use it.
I don't know anything about this part help please.
« Last Edit: 31 October 2012, 14:38 by tweed »
Offline 67buggers
Re: Need help with electric side of engine swap.
« Reply #1 on: 30 October 2012, 21:53 »
I don't know for sure but would hazard a guess yes because it's either plug n play as its standard and will therefore still be plug n play with the vr lump/loom or it's added into the gti loom at the dealers so could be added into the vr loom in the same way.......that make sense?
I fix iPhone's and iPod's, I can fix most faults call me on 07811344816 for a quote
Offline madmanmart
« Reply #2 on: 30 October 2012, 22:11 »
Yes it should be an easy job, Your Laser alarm will be wired in the same as any other aftermarket alarm because as far as I know no alarms for the mk3 were factory fit. It was no doubt a dealer fit.
When I did an engine conversion it was just a case of finding the alarm wires that are linked into the engine harness and then wiring them to the new engine harness after the swap.
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline benvictors
  • bgk Tuning - coming soon!!!
« Reply #3 on: 30 October 2012, 23:07 »
In my experience all factory alarms were wired into the car loom, not the engine loom. They are generally bridged onto the starter motor live feed which isn't on the loom you will be replacing so happy days  :wink:
Offline tweed
« Reply #4 on: 31 October 2012, 05:47 »
Sweet as nice one guys  :cool:
Offline Stewy12
« Reply #5 on: 31 October 2012, 06:56 »
When i removed my laser alarm there was one wire going to the engine loom under the scuttle panel (BLACK) wire it was part of the immo side of things just traced it and rejoined...
Offline tweed
« Reply #6 on: 31 October 2012, 12:23 »
Nice cheers mate. Ill label them up.
Offline tweed
Re: Need help with electric side of engine swap. And now AC
« Reply #7 on: 31 October 2012, 14:39 »
Gti AC pump same as vr6? Will it all bolt up ok?
Offline tweed
« Reply #8 on: 01 November 2012, 08:30 »
Anyone know if the gti air con can be used on the vr6?
Offline Len
« Reply #9 on: 01 November 2012, 15:36 »
Had a look on Vagcat for ya and the compressor itself looks the same but the mounting bracket is different.
As for the rest of the aircon I would assume they are the same.
www.sas.org.uk
www.the-ace.org.uk
