Author Topic: started fitting 'the beast' *pics*  (Read 9840 times)
Offline rio_gti
Re: started fitting 'the beast' *pics*
« Reply #30 on: 16 October 2012, 18:17 »
Hot side from cooler; a 63mm 90* silicone bend, 63mm 90* alloy bend, 63mm 90* silicone bend, 63mm 300mm straight alloy coupler, 63mm 45* Silicone bend, 63mm 45* alloy bend (with n75 & dv take offs), 63mm 90* silicone, 63mm alloy couple 100mm long, 63mm-45mm Silicone reducer onto the turbo outlet.
hope that helps  :wink:
top man!!... would love that cold side pipe but they wont sell it seperatly  :sad:
do you recon this 100mm pipe would be too close to the turbo to have the d/v and n75 take off on it??
Offline cooki
  • 1.8T AUM
« Reply #31 on: 16 October 2012, 23:19 »
When ordering/fitting a FMIC do I need to keep an eye out for the MAP sensor flange,aswell as the dv&n75 takeoffs??
I'd always just thort that all I needed was the MAP sensor flange???
Well confused now.
1.8T AUM,18"s,full koni suspension kit,forge split r on fully recirc,k&n induction with cold air feed,FMIC,r32 front,colour coded rear valance,black front and rear VW badges,5 door wind deflectors,boost gauge an volt metre in A pilla pod,full brushed alluminum net optic interior,full creame heated interior,
PLANS: catback exhaust&remapp her  :) :) :)
Offline Chris#101
« Reply #32 on: 17 October 2012, 12:27 »
yer I was quite fortunate that the cold side already 2.5", dunno why they had to restrict the hot side to 1.75" :sick:
My 100mm alloy joiner isnt even visible as both the silicone joints touch because of the restricted height issue. So had to use the alloy.45* for take off points
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Chris#101
« Reply #33 on: 17 October 2012, 12:31 »
Well confused now.
What weve done is DIY'd a fmic kit ie brought eve ything individual. If your buying a kit it should already have the take offs needed. If it doesnt have a map flange forge sell them for £40 then you just need.to get it welded :wink:
Offline rio_gti
« Reply #34 on: 17 October 2012, 12:44 »
if this is with 150mm legs can it be cut down or did you have to cut the 90 on top of the turbo (100 mm ally pipe) down to fit?
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #35 on: 17 October 2012, 13:25 »
I'm pretty sure I'v seen smaller cars than that IC! It's hugeeeeee!!
What sort of gain are you hoping to achieve from it?  :smiley:
Offline rio_gti
« Reply #36 on: 17 October 2012, 15:16 »
 :grin:
gonna be going hybrid so the standard side mount wouldnt be any good  :nerd:
Offline cooki
  • 1.8T AUM
« Reply #37 on: 18 October 2012, 10:38 »
Well confused now.
Mines turning in to a bit or a diy kit its self mate.i no i can get the map flange from awsome gti or forge and the dv take off is already fitted but what did u use for a n75 valve take off?is it jist a smaller version of the dv take off??
Offline rio_gti
« Reply #38 on: 10 February 2013, 22:17 »
just thought i would put the results of the intake temps up as its now running.
wasnt to redline but at:
5200rpm the standard intercooler was at 36 degrees c
5200rpm the 'beast' was showing at 12 degrees c
very pleased at the results  :smiley:
Offline Toby
  • Car - less
« Reply #39 on: 10 February 2013, 22:42 »
So good for the price!!
Currently down under
