Author Topic: 1.8t anniversary best induction kit and simple dv Q  (Read 4854 times)
Offline DunnDeal12
  • Limited
Re: 1.8t anniversary best induction kit and simple dv Q
« Reply #10 on: 29 September 2012, 11:58 »
yea cully i can understand on a type r as the as cai is directly connected to the throttle body, where as a turbo car is different the water has to travel past the turbo which in my eyes seems impossible as the turbo would just stall.
a little amount of water in the inlet is good as you've seen with water injection.
« Last Edit: 29 September 2012, 12:17 by DunnDeal12 »
Offline cullygti
« Reply #11 on: 29 September 2012, 14:53 »
yes i was thinking the same aswell  :smiley:
Offline shaft69
« Reply #12 on: 29 September 2012, 18:32 »
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline DunnDeal12
  • Limited
« Reply #13 on: 29 September 2012, 19:27 »
If read at bottom see what people who make CAI say!!!!
http://www.neuspeed.com/31/11/0/1525/651076-neuspeed-race-series-cold-air-intake-kit.html
Yes shaft69 read it, now what part of that sentence states about water getting into the engine??? NONE!!!
Offline golfyste
  • Project track car
« Reply #14 on: 29 September 2012, 20:14 »
Even if the Turbo stale the would still be vacuume from the inlet manifold sucking the water into the engine like a n/a car does.
Offline DunnDeal12
  • Limited
« Reply #15 on: 29 September 2012, 21:52 »
if the turbo stalls then the engine will cut out. Have you ever had a boost pipe pop off? same thing.
« Last Edit: 29 September 2012, 21:55 by DunnDeal12 »
Offline golfyste
  • Project track car
« Reply #16 on: 29 September 2012, 22:04 »
Yews I have had a boost pipe pop off, the engine didn't stall tho just had no boost, drove the extra 100m home, had a look and found it had popped off.
If the turbo stalled the engine wouldn't cut out as it doesn't take boost at idle so it wouldn't make a difference and you would still have vacuume from the manifold which would suck the water in
Offline DunnDeal12
  • Limited
« Reply #17 on: 29 September 2012, 22:56 »
Bloody hell mate you must have a special car then cuz when mine blows a pipe off the engine will stop as there's unmetered air entering the system what do you think the MAF is for?
So your telling me that the engine wouldn't stop after gallons of water has just hit the turbo?
Offline golfyste
  • Project track car
« Reply #18 on: 29 September 2012, 22:58 »
So your tellin me when ever the mafs reading isn't right the engine cuts out?? No it just runs badly
And yeah otherwise there wouldn't be people out there who have hydrolysed their engines...
Offline DunnDeal12
  • Limited
« Reply #19 on: 29 September 2012, 23:24 »
I'll do a video for you tomorrow mate to prove my point.
i will believe it when i see it
