Author Topic: loosing boost?? update.  (Read 9307 times)
Offline rfn_hodgson
Re: loosing boost?? update.
« Reply #20 on: 28 October 2012, 09:36 »
VW Golf MK4 1.8 Turbo AUQ 203 BHP-more now :) , ultimate vacuum delete, Forgre 007p-new piston, Oil catch can, s3 boost set up, FMIC, silicone TIP, full turbo back exhaust, stage 1 map, lowered on V-maxx coilovers  audi tt Quattro alloys
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #21 on: 28 October 2012, 09:48 »
you tried all the breather pipes mate? Who mapped it?
Offline rfn_hodgson
« Reply #22 on: 28 October 2012, 10:50 »
breather pipes?- to do with the oil catch can ?? a tuning complex near me called top gear performance, i only went there because my mate has had his done there and no problems, the map it self wasn't a custom one as such it was like a bulk map if you know what i mean.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #23 on: 28 October 2012, 11:16 »
yeah those pies, just to see if they are all ok etc.
It might be worth asking them if they could have a look. Just tell them it's happened since the remap
Offline dan2252
« Reply #24 on: 28 October 2012, 11:17 »
There's your problem dude get a proper map.. Who was it? Danny who mapped it? Mine has one of there maps and I can't wait to get it done somewhere else. But if that's not the issue try changing n75 valve that went on mine,
MK4 golf 1.8 turbo agu :)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #25 on: 28 October 2012, 11:41 »
I'm sure there is a problem with certain AUQ ECUs that needs sorting when you map them, Topher will probably know more
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #26 on: 28 October 2012, 11:43 »
Boom, from R-Techs website
We have been updated with many emails from 1.8T 20v owners which have Golf, Seat & Skoda VRS with the AUM and AUQ engine codes. They have reported issues of there remaps from other tuners causing boost surge and 17705 limp mode / fault codes.
The fault IS based in the OEM mapping and once  remapped the fault is highlighted and becomes a really anoying issues when trying to drive the car in a smooth linear style.
Offline dan2252
« Reply #27 on: 28 October 2012, 23:07 »
he wants to take it somwhere proper for mapping i live local to the place he took it they do custom exhuasts and now theyve started doing remaping.....
Offline rfn_hodgson
« Reply #28 on: 02 December 2012, 07:09 »
Ok guys so I've had It hooked up to a propper diagnostic machine and the codes are
P1297 and p1560
Once again cheers for the help :)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #29 on: 02 December 2012, 08:43 »
17705/P1297/004759 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Power Loss
Possible Causes
Leaking Hoses and/or Pipes between Components
Boost Pressure Control Valve (N249) faulty
Diverter Valve faulty
Throttle Body dirty
Vacuum leak
Possible Solutions
Check Hoses and Pipes between Components
Check / Replace Boost Pressure Control Valve (N249)
Check / Replace Diverter Valve
Check / Clean Throttle Body
Perform Throttle Body Alignment (TBA)
Check for Vacuum leak(s) including PCV system
Special Notes
Did anyone install an extra (wrong) dump valve? When found in the NAR 2.0T (BPY) check RVUTB: 01-09-03 or 2018919 for updated Crankcase Breather ValveIf the breather valve is faulty, full engine vacuum is typically found when removing the oil cap at idle.
