Author Topic: loosing boost?? update.  (Read 9329 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: loosing boost??
« Reply #10 on: 23 September 2012, 13:40 »
turning the engine off and starting it again resets the limp mode
As you have an AUQ check the pipe down the back of the engine to comes from the turbo to the pancake pipe. The join on yours is held on with with clips and fail for fun. If you find you need an AGU version (which is a jubilee and much better for sealing) Chris has one for sale in the classifieds
sorry to jack this thread, but i've installed a newsouth PSI boost gauge and when the engine is running it sits at about 9-10HG
That's a bit low mate, should be about -20in hg
Offline sam1990
Re: loosing boost??
« Reply #11 on: 24 September 2012, 02:58 »
sounds like it could be a faulty map sensor (unless your running an agu the it doesnt even have a map sensor) have you got any friends with a 1.8t? you could try there map sensor to diagnose
Offline GTi_James
Re: loosing boost??
« Reply #12 on: 24 September 2012, 08:43 »
yeh just checked it and it sits at -20in HG
Offline rfn_hodgson
Re: loosing boost??
« Reply #13 on: 08 October 2012, 20:32 »
ok so a bit of an up date..... when i plug it in.... no fault codes. so we took it for a good test drive and it went into limp mode and still no codes popped up.
really confused right now :(
any ideas ?
VW Golf MK4 1.8 Turbo AUQ 203 BHP-more now :) , ultimate vacuum delete, Forgre 007p-new piston, Oil catch can, s3 boost set up, FMIC, silicone TIP, full turbo back exhaust, stage 1 map, lowered on V-maxx coilovers  audi tt Quattro alloys
Offline Dalo Harkin
Re: loosing boost??
« Reply #14 on: 10 October 2012, 12:20 »
what reader were you using?
if you try the basics, unplug MAF and see if its better.
check for oil from/on pipes (indicating a boost leak)
is it when it gets warm? or all the time?
etc
Offline rfn_hodgson
Re: loosing boost??
« Reply #15 on: 10 October 2012, 13:11 »
it can happen sometimes form start up and some times 30mins down the road and as i found out driving up to scotland 3hours up the road?, it happens irregulary. i was looking at the pipes yesturday and i noticed the pipe going from the turbo to the pancake pipe has got a fair amount of dirty old oil around near the joint, must be a boost leak from there then.
wazzer has advised me to get the charge pipe from an AGU so im just wanting on that now.
just out of interest how hard/ much of a b*&%h is it to change the charge pipe??
Offline jamie1989
Re: loosing boost??
« Reply #16 on: 10 October 2012, 13:13 »
Really easy mate, if you never done it before its a 30min job if that.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline Dalo Harkin
Re: loosing boost??
« Reply #17 on: 10 October 2012, 13:15 »
It is easy provided you have the right tools, the hardest part for me was getting the support bracket main bolt out because I couldnt see a damn thing and had to feel with my hands lol
Offline rfn_hodgson
Re: loosing boost??
« Reply #18 on: 10 October 2012, 16:34 »
cheers fellas
Offline rfn_hodgson
Re: loosing boost?? update.
« Reply #19 on: 26 October 2012, 20:20 »
well ive changed the charge pipe to the AGU one and i do notice it holds the boost longer. but im still going into limp mode and chriss plugged it into his vag com and no codes.....
any other ideas??
« Last Edit: 27 October 2012, 12:30 by rfn_hodgson »
