Author Topic: loosing boost?? update.  (Read 9301 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: loosing boost?? update.
« Reply #30 on: 02 December 2012, 08:49 »
17968/P1560/005472 - 17968 - Maximum Engine Speed Exceeded (Engine Warranty VOID! ☺ )
Possible Symptoms
Abnormal Engine Noises
Possible Causes
Rev Limiter Removed, check to see if ECM has been 'Tuned'.
Engine Speed too fast due to a mis-shift or the "Money-Shift".
Stuck throttle.
Possible Solutions
Clear Fault Codes
Remove Lead from Foot :laugh:
Special Notes
This DTC indicates that the Engine Speed has passed the recommended safe RPM limit, which may potentially cause severe engine damage.
Offline rfn_hodgson
« Reply #31 on: 02 December 2012, 12:37 »
17705/P1297/004759 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Power Loss
Possible Causes
Leaking Hoses and/or Pipes between Components
Boost Pressure Control Valve (N249) faulty
Diverter Valve faulty
Throttle Body dirty
Vacuum leak
Possible Solutions
Check Hoses and Pipes between Components
Check / Replace Boost Pressure Control Valve (N249)
Check / Replace Diverter Valve
Check / Clean Throttle Body
Perform Throttle Body Alignment (TBA)
Check for Vacuum leak(s) including PCV system
Special Notes
Did anyone install an extra (wrong) dump valve? When found in the NAR 2.0T (BPY) check RVUTB: 01-09-03 or 2018919 for updated Crankcase Breather ValveIf the breather valve is faulty, full engine vacuum is typically found when removing the oil cap at idle.
Possible Causes
Leaking Hoses and/or Pipes between Components - changed charge pipe to agu one, and ive got silicone pipes all round
Boost Pressure Control Valve (N249) faulty- where is this in the engine bay ??
Diverter Valve faulty- ive got a forge 007p and its working fine
Throttle Body dirty- cleaned about 2 months ago ish
Vacuum leak
Possible Solutions
Check Hoses and Pipes between Components- check
Check / Replace Boost Pressure Control Valve (N249)-?
Check / Replace Diverter Valve- check
Check / Clean Throttle Body- check
Perform Throttle Body Alignment (TBA)- check
Check for Vacuum leak(s) including PCV system- ive got oil catch can would that cause issues??
once again cheers in advance much appreciated
VW Golf MK4 1.8 Turbo AUQ 203 BHP-more now :) , ultimate vacuum delete, Forgre 007p-new piston, Oil catch can, s3 boost set up, FMIC, silicone TIP, full turbo back exhaust, stage 1 map, lowered on V-maxx coilovers  audi tt Quattro alloys
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #32 on: 02 December 2012, 12:54 »
shouldn't do if all the hoses are air tight. Check every hose from the turbo to the throttle housing for splits etc, then move on to the N249 and DV hoses. It really could be anything
Offline GTi_James
« Reply #33 on: 02 December 2012, 15:22 »
... Remove Lead from Foot :laugh: ...
 :lipsrsealed:  :whistle:
