Author Topic: Engine tidy now thinking oil seals  (Read 3081 times)
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
« on: 10 September 2012, 18:25 »
I'm in the process of tidying the engine bay up and I'm getting a bit carried away!! I'm getting all the aluminum parts cleaned. Question is whether to do the oil seals whilst its all off. Engine has done 140k and was using a little oil. (may have been from rocker gasket). I know it is possible to do the seals without the head comming off but this looks like a lot of hard work and  grinding the valves back in must be a good thing right?. It's an abf engine, are the gaskets any more prone to failing once removed.  I've seen the full gasket set for £70 inc the bolts which I thought was quite reasonable.
Offline Mr Blue
Re: Engine tidy now thinking oil seals
« Reply #1 on: 10 September 2012, 19:20 »
Unless the rocker gasket was throwing lots of oil out then that would be one way it was losing oil. I would take the head off and change the lot while its out but thats just me.
Gearbox flange seals also. Quite easy to do with the box out :smiley:
« Reply #2 on: 10 September 2012, 20:00 »
not planning on removing the gearbox to be honest that is a step too far. anything else worth doing? I use the car everyday so want to give it a good going over. was thinking new sensors too. I've already bought a new lambda.
« Last Edit: 10 September 2012, 20:03 by oakgreengolf »
« Reply #3 on: 13 September 2012, 09:16 »
Will the head have to be skimmed or is this only if it over heats.
Offline Diamond Hell
  • Opinions я Us
« Reply #4 on: 13 September 2012, 09:58 »
If it's not leaking it, it's burning it.
Would suggest it could be valve stem seals, or piston rings.  Check for smoke when it's started from cold - this would be stem seals.  Do a compression test to see if everything's evens for piston rings.
Head would need to be checked to decide whether it needs skimming - needs to be straight and true and flat - metal rule on edge would decide this for you.
If/when you take it off, undo the bolts in sequence.
« Reply #5 on: 13 September 2012, 12:05 »
Readings where all good when I did a compression test recently. Are new guides recommended or is it a case of seeing how much play there is in the valves.
Offline Gambit
« Reply #6 on: 13 September 2012, 15:52 »
what where you compression results? ideally you want in & around 200psi per cylinder
if you are having the head done then do the guides, no need to skim unless overheated as you say, though skim can help lift compression a wee hair also!
all depends how much you wanna do. if you are taking head off you can even change piston rings & big ends with the block & gearbox in place, just remove sump for access
« Reply #7 on: 13 September 2012, 19:25 »
Just done it again and I'm getting 230psi across all 4 does this sound high. I've got the inlet manifold off if that makes any difference.
Offline Gambit
« Reply #8 on: 13 September 2012, 20:39 »
Is that dry compression test across all 4 cylinders? it is high but higher the better, if it is then its in great health!
At that psi i would not be touching the block and cylinder head leave it as is. You can replace inlet, exhust manifold, cam cover gaskets but dont be removing head
« Last Edit: 13 September 2012, 20:45 by Gambit »
« Reply #9 on: 13 September 2012, 20:57 »
Yes that's dry tested.  I was going to replace oil seals whilst I was refurbishing manifolds, perhaps I should just change the rocker gasket and see what happens to the oil usage.
