Author Topic: Engine tidy now thinking oil seals  (Read 3082 times)
Offline Gambit
Re: Engine tidy now thinking oil seals
« Reply #10 on: 13 September 2012, 21:27 »
What grade of oil are you using?
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
« Reply #11 on: 13 September 2012, 21:54 »
10/40 semi synthetic.
Offline Gambit
« Reply #12 on: 13 September 2012, 22:23 »
Dead on so we know youre using the correct grade. How much oil was it using? If it was me and with those compression readings id just Change the cam cover gasket, and give it an oil change but only fill it till halfway between max n min, and then monitor it
can you see it burning oil when driving at all?
« Reply #13 on: 14 September 2012, 10:35 »
It does smoke but mainly from cold which I suppose is condensation build up as its left standing now and then.  I've had an 8v before and this was very smokey especially when you gave it a bit if welly. I'm getting no excessive smoke when I acceleratE either.
Offline Gambit
« Reply #14 on: 14 September 2012, 11:32 »
condensation/steam out of the exhaust on cold mornings aint smoke, you are looking for blue smoke but if you are seeing none then id be inclined to leave as is and just do the cam cover gasket and any other gaskets you fancy doing bar splitting the head from the block
if you brim 16v's with oil then they all tend to burn a bit hence run them at halfway.
get a mate to follow you as you boot it down the road, and then coast down on overrun then floor it again. he'll be able to see does it smoke on acceleration/deacceleration as its not always easy for you to see out the rear window for it unless its really bad
but the fact you are getting 230psi shows the engine is very healthy
