Author Topic: Cold Air Induction Kit install on a 1.8t AUM  (Read 9392 times)
Offline Gary022
« on: 09 September 2012, 15:43 »
Thanks to alot of help from golfgtiforum members ive managed to succesfully install the cold air induction kit i bought.
The pipework needed to be cut in half , a new end filter had to be bought  and the battery removed but its in looks and sounds great.
Heres some pictures of the install:
Cheap and nasty ebay cold air intake i bought:
Better quality filter from k and n with the right angle to fit past my battery:
Pipework in place:
Oil breather connection:
Finished article:
Uploaded with ImageShack.us
 :cool:
« Last Edit: 09 September 2012, 15:46 by Gary022 »
Mk4 Golf Gti 1.8T
Custom K&N CAI / Forge 008dv / 3" Turbo Back Exhaust with Highflow Sports Cat / Pressed Plates / Carbon Wrapped Interior Trim / 18" BBS CH Reps
Offline JimBR
Re: Cold Air Induction Kit install on a 1.8t AUM
« Reply #1 on: 09 September 2012, 17:40 »
Gold star for you :grin:
Offline DubAndDubber
« Reply #2 on: 09 September 2012, 20:15 »
Why did you need to cut it in half?
Mk5 Golf Gti 06'
Offline james2
  • No scammers please.
« Reply #3 on: 09 September 2012, 21:12 »
Love it.The filter looks good. It looked small in the last link.  :cool: Bet you love the induction roar and the dump valve noise. Top job.  :wink: Also iv got a flex cold air feed off the front bumper (where the horns are) i removed the bottom horn so my tube could sit there.It comes up just under the filter.
« Last Edit: 09 September 2012, 21:18 by james2 »
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
« Reply #4 on: 09 September 2012, 21:17 »
Will that not suffer heat soak where it is mounted  :undecided:
Offline james2
« Reply #5 on: 09 September 2012, 21:23 »
It work better then having it behind the bumper for some reason. I went on a 98 mile trip,got out and felt the alloy tube and it was cold. But i do have a cold air feed under mine.
Offline james2
« Reply #6 on: 09 September 2012, 23:09 »
The cai kit used to point to the floor. It had air flowing past it from the front lower bumper vent. Have you ever turned your head side ways on from a 100mph wind ,you cant breath (takes your breath away).  :grin:
Offline Gary022
« Reply #7 on: 10 September 2012, 10:17 »
Cut in half cause judging the size of it I wouldnt trust it with the Scottish weather , plus am wanting to drive a golf not a road sweeper haha
Mk4 Golf Gti 1.8T
Offline Gary022
« Reply #8 on: 10 September 2012, 10:20 »
Reckon it should ok cause there's a fair sizes hole in the engine bay where ma
Filters sitting so it's getting plenty air and a fine breeze lol
Mk4 Golf Gti 1.8T
Offline Dalo Harkin
« Reply #9 on: 10 September 2012, 17:47 »
Looks good, but when it rains, the water will drop straight onto the filter, I only noticed because I was going to place mine there and then noticed when I opened the bonnet how much water fell exactly where the filter would be same as yours (now, I dont know if it was just because I lifted the bonnet or not but I thought sod that)
