Author Topic: Cold Air Induction Kit install on a 1.8t AUM  (Read 9852 times)
Offline Gary022
Re: Cold Air Induction Kit install on a 1.8t AUM
« Reply #10 on: 10 September 2012, 18:25 »
Looks good, but when it rains, the water will drop straight onto the filter, I only noticed because I was going to place mine there and then noticed when I opened the bonnet how much water fell exactly where the filter would be same as yours (now, I dont know if it was just because I lifted the bonnet or not but I thought sod that)
surely it would just be because you opened the bonet , cant see water getting in there as the electrics for the headlights have been sound  :wink:
Mk4 Golf Gti 1.8T
Custom K&N CAI / Forge 008dv / 3" Turbo Back Exhaust with Highflow Sports Cat / Pressed Plates / Carbon Wrapped Interior Trim / 18" BBS CH Reps
Offline Dalo Harkin
« Reply #11 on: 12 September 2012, 17:10 »
I dont know, nothing seals the edge of the bonnet to the wing, so would presume it would happen anyway, and the headlights and associated wiring are surrounded in plastic  :wink:
Offline Gary022
« Reply #12 on: 12 September 2012, 18:38 »
had mine on in aberdeen for a week which basically means its seen the equivalent to 6 months rain in england and its coping fine , not found any water under the bonet and the pipe is dead cold after a reasonable run so dont think its suffering from heat soak either.  :smiley:
Mk4 Golf Gti 1.8T
Offline james2
  • No scammers please.
« Reply #13 on: 12 September 2012, 18:59 »
Had mine there for 2 years ,with no problems.  :smiley:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline Dalo Harkin
« Reply #14 on: 12 September 2012, 19:57 »
So begs the question does all this cost actually do much for performance over a standard box and decent panel filter   :rolleyes:
Offline james2
« Reply #15 on: 12 September 2012, 20:17 »
Yeah it kick the airboxes arse.  :wink: I put my smooth airbox in a skip and the k&n panel filter.  :drool: Well my dad did .  :grin: I dont mind as i would of never gone back.  :smiley: It does make a world of a difference in sound ,good dump valve noise and better performance .I can fell its better. I have to try every kind of mod tell i find one thats better. Like spark plugs ,you cant beat ngk platinum PFR6Q .I tryed nology ,denso and the £100 pluse plugs ,they where a fail big time.  :rolleyes:
