Author Topic: tt stuff  (Read 2264 times)
VeeDubGTI16v
tt stuff
« on: 04 September 2012, 18:35 »
ok so i'm thinking of doing the tt front hub conversion for better handling, does it make a noticeable difference? i'm fully arb'ed up now with billy b4's and eibach springs and it could do with handling better still!
basically, is it worth the effort  :huh:
Offline topher
  • Administrator
  • fully functioning
Re: tt stuff
« Reply #1 on: 04 September 2012, 19:17 »
it does make a difference and the adjustability is nice, but the TT upper and lower front strut braces make more of a difference imo
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: tt stuff
« Reply #2 on: 04 September 2012, 19:20 »
how about the whole lot lol
Offline Prawny
  • R-tech power!!!
Re: tt stuff
« Reply #3 on: 05 September 2012, 11:26 »
I'd have to disagree massively with that statement Topher.
Fitting the upper and lower braces stiffens things up, but doesn't actually change anything to deal with the mk4's terrible standard wishbones or uprights.
Fitting the TT wishbones and uprights, gives you more negative camber, more caster, more adjustability, a higher roll centre (which is desirable), and less bump steer issues.
It's a massive improvement to the way the car drives. far more than any strut brace could ever do.
VeeDubGTI16v
Re: tt stuff
« Reply #4 on: 05 September 2012, 13:09 »
What's adjustable on the tt setup?
Offline Prawny
  • R-tech power!!!
Re: tt stuff
« Reply #5 on: 05 September 2012, 13:37 »
still not a great deal to be honest!
There is much more camber adjustment in the TT setup, but the main thing is the additional gain in camber and caster that they give you.
VeeDubGTI16v
Re: tt stuff
« Reply #6 on: 05 September 2012, 13:49 »
oh ok, I assume on the balljoint?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: tt stuff
« Reply #7 on: 05 September 2012, 17:31 »
the three threads for the ball joint have eccentric slots in the actual wishbone
VeeDubGTI16v
Re: tt stuff
« Reply #8 on: 25 September 2012, 19:26 »
so would the tt parts list be-
dampers
hubs/uprights
wishbones
arb
do i have to use the tt rack or just rod ends?
ta
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: tt stuff
« Reply #9 on: 25 September 2012, 21:20 »
ideally rack as well as it's less turns from lock to lock
