Author Topic: ABS Fault/ Brake lights on dash  (Read 3679 times)
Offline emy_mk3_gti
« on: 04 September 2012, 13:08 »
Hi All.
Wondering if we have any whizz's here regarding brakes/abs.
My ABS light used to intermitantly go out but now stays on all the time (I am well aware that the ABS is not working).
The handbrake light on the dash is also staying on.
The handbrake itself is working fine, isn't sticking and there isn't a huge amount of travel when on.
I believe both lights on suggest an ABS fault.
Front and rear disc and pads still have alot of use left in them.
Front ABS sensors and ABS rings changed about 18months ago.
Would changing the rear ones help?
Last time my GTI was in for a service they had a matey boy from VW test it and he werent able to determine what was causing the fault (which i think is a little ludricous).
So any suggestions most welcome
Emy
« Last Edit: 04 September 2012, 18:52 by emy_mk3_gti »
My brakes are good.......how about your insurance?
Offline sharki786
  • GOT BOOST??
Re: ABS Fault/ Brake lights on dash
« Reply #1 on: 04 September 2012, 14:10 »
check you brake fluid as a 1st step. Then get vaj com hooked on it for any errors. Wipe them and check again if they come up again (should tell you which abs sensor it is front or rear) if they still come up get live data from it by having it hooked up and drive (should tell you the speed of each sensor if 1 is lower then the other 1 then clean it and try again) if all fails then its the abs ecu which is common.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline emy_mk3_gti
« Reply #2 on: 04 September 2012, 14:23 »
Hi there.
Had a brake fluid service in January so I would hope not that.
And then hook "what" on it for errors? You mean me or take to a garage? (Sorry for being dim)
Offline Screech16v
  • MK3 20vt AGU
VW BUSH
« Reply #4 on: 04 September 2012, 16:55 »
Check the little plunger cover on the fluid reservoir is there, they crumble away and the plunger pops up giving you the light on the dash and you have just had it serviced.....Need to make sure this is right as ABS light and Handbrake light can mean a specific fault on certain cars.
As said before, get a code reader ( I have a U281 code reader so can back screech up) they are only £15ish :wink:
Offline Screech16v
  • MK3 20vt AGU
« Reply #5 on: 04 September 2012, 17:14 »
From what i gather,he is saying his handbrake light is not also staying on  :laugh:
Offline sharki786
  • GOT BOOST??
« Reply #6 on: 04 September 2012, 18:17 »
hahaha i also thought the same.
Go to a garage and ask for a vaj com (diagnostic) this will connect to the on board computer which logs faults (if there is 1 & in your case there is) it will read it and tell you whats the matter with the abs.
*****MK4 GTI T*****
Offline brett
« Reply #7 on: 04 September 2012, 18:39 »
i also have this problem buttttt ,hopefully goin to look at another car saturday  mmm,then it will be decision time on what to do with mine  :undecided:
Offline madmanmart
« Reply #8 on: 04 September 2012, 18:50 »
If your brake fluid is topped up and the handbrake switch is working fine the the light staying on constantly means complete failure of the brake bias system which is controlled by the ABS ECU.
Get the car scanned for fault codes.
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline emy_mk3_gti
« Reply #9 on: 04 September 2012, 18:52 »
Lol.
Firstly, he is a she :) secondly, I did make a typo there.
Both lights are staying on
