Author Topic: ABS Fault/ Brake lights on dash  (Read 3680 times)
Offline emy_mk3_gti
Re: ABS Fault/ Brake lights on dash
« Reply #10 on: 04 September 2012, 18:54 »
Buy this it will help you pin point your problem and you will use it over and over  :wink:
http://www.ebay.co.uk/itm/U281-VW-Audi-Skoda-Seat-VAG-CAN-BUS-Fault-Code-Reader-Scanner-diagnostic-tool-UK-/300771386986?pt=UK_Diagnostic_Tools_Equipment&hash=item46075f266a
I have just ordered one of those "things". Never heard of one before.
I hope it is easy to suss out :)
Thanks
My brakes are good.......how about your insurance?
Offline brett
« Reply #11 on: 04 September 2012, 18:58 »
i'm pretty sure mines the abs ecu as plugged it in other day and only came up with 2 faults ,bout 2hrs later all sensors and the abs pump was showing a fault ,soi think  thats mine fubarred  lol
Offline emy_mk3_gti
« Reply #12 on: 04 September 2012, 19:03 »
Oh bad times :(
I have always had probs with the ABS light (i stick electrical tape over it for the MOTs)
Don't think I will get away with the "tape trick" on the other light though
Offline madmanmart
« Reply #13 on: 04 September 2012, 19:10 »
Lol.
Firstly, he is a she :) secondly, I did make a typo there.
Both lights are staying on
Yes i did mean both lights staying on  :wink:
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline AcidicDavey
  • Not a VAG Owner.
« Reply #14 on: 04 September 2012, 19:10 »
You won't get away with sticking tape over it any more, all dash lights need to function correctly to get through an MOT even the washer fluid light!  :laugh:
95 Volvo 480 2.0 Celebration
Offline emy_mk3_gti
« Reply #15 on: 04 September 2012, 19:17 »
Ahh really?! When did that change.
Bloke I take my car to always said "if we cant check it then we cant fail it".
Well I have ordered that testy thing of EBAY. Will see what it's reading when it arrives and take it from there then I guess...........
Offline AcidicDavey
  • Not a VAG Owner.
« Reply #16 on: 04 September 2012, 19:19 »
Earlier this year I believe, most testers would probably over look this though I imagine if you were friendly with them  :wink:
Offline Screech16v
  • MK3 20vt AGU
« Reply #17 on: 04 September 2012, 19:28 »
Apologies emy  :embarrassed:,if both lights are on then as said could point towards a duff abs controller,tbh when the ecu gives up it can throw random fault codes like mine did,the main one being the rear right even though that sensor was all ok,theres a guy on here russ goes by username Tshirt2k who did a great job on my abs ecu a while back ,give him a shout if you dont sort it as trying to find another working ecu with the correct part number is pretty hard,good luck!  :smiley:
Offline AcidicDavey
  • Not a VAG Owner.
« Reply #18 on: 04 September 2012, 19:32 »
My handbrake light is constantly on but I think my ABS light has blown as it doesn't self check and it looks a bit knackered!
VW BUSH
« Reply #19 on: 04 September 2012, 19:32 »
Do check the cap on the reservoir, as if you have both lights on for a fault you should not be driving the car as it is dangerous (even ABS light will void MOT in time of a crash) :wink:
