Author Topic: ABS Fault/ Brake lights on dash  (Read 3694 times)
Offline emy_mk3_gti
Re: ABS Fault/ Brake lights on dash
« Reply #20 on: 04 September 2012, 19:38 »
Ok, remembering I know nothing about ABS and brake fluid, where is the reservior cap located? Will check that and then plug this fault reader in to see what that is saying.
I am not using my car alot at the moment anyway.
The fact that "occasionally" and I mean occasionally, the handbrake light does go out again (just not as often), would that point the fault towards any particular direction do you think?
Thanks for everyones help, much appreciated
My brakes are good.......how about your insurance?
Offline sharki786
  • GOT BOOST??
« Reply #21 on: 04 September 2012, 19:41 »
im pretty sure that i have read somewere that the abs ecu connections can corrode due to moisture and there was a guide somewere to show you how to get it all working again.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline emy_mk3_gti
« Reply #22 on: 04 September 2012, 19:43 »
Hi Sharki786,
If you happen to find it, could you poss post a link on here.
Offline AcidicDavey
  • Not a VAG Owner.
« Reply #23 on: 04 September 2012, 20:16 »
Open Bonnet and it's by the driver's side bonnet hinge.
95 Volvo 480 2.0 Celebration
Offline sharki786
  • GOT BOOST??
« Reply #24 on: 05 September 2012, 18:59 »
best bet is google golf mk3 faulty abs ecu.
I wouldav done it but im at work and on my mobile phone.
Sorry
*****MK4 GTI T*****
Offline emy_mk3_gti
« Reply #25 on: 06 September 2012, 15:35 »
I changed the oil yesterday and straight away foudn the brake fluid reservoir, was being a dumbass the other day
All looks ok though. The handbrake light had a whole day without coming on at all (apart from when parked obvs).
Then today its on again.
The fault tester should arrive tomorrow, fingers crossed :)
Emy
